Question about Freezers
Freezer not working
Hi ihave a whirlpool s20b-rbb20 american style fridge freezer with a fault, the freezer refuses to work and the alarm will sound unless i press the fast freeze button which then works perfectly? any ideas would be brill please.
  • 1 more comment
  • ihaveaprob Dec 19, 2007
    Hi thanks for that just realised if i switch off and on a few times it works without having to press fast freeze, but as soon as it reaches correct temp it switches off like it should but never comes back on again??? any ideas please!!
  • ihaveaprob Dec 22, 2007
    Hi thankyou for all the help, just found out it was a faulty relay on pcb. your help was much apprieciated thank you very much.
  • derk63 Jan 06, 2008
    My poblem is, alarm constantly goes off about three times an hour. it goes off just prior to compressor kicking in, then switched off about thirty seconds later. The temperature is well below freezing. I believe it it is a problem with a thermister and can be by-passed?
    this is a bosch 3.2 cu in. under counter freezer
    Champion:
  • 249 Answers
The thermostat may be faulty
Posted on Dec 18, 2007
  • eamonn close Dec 19, 2007
    It could be still be the stat its only 'thing'that controls the motor compressor! close.
  • 126 Answers
Sounds like a cold control problem
  • john fraser Dec 19, 2007
    replace cold control.not that expensive
Have american style fridge freezer, model S25B RSB31. Seems to be tripping the electricity supply. When power restored, find that the freezer has two bars where you would see -18c. After putting in and...
Your defrost heat element is shorting, resetting will make it work till defrost cycle kicks in and HEY PRESTO""shorts again...very common fault and bugs the hell out of all of us, check it and I am pretty sure that is the fault. Or you are getting water or condensation in the control panel but very rare.
Regards and hope that sorts the issue...Please dont forget to Vote, I do this for free, Russ
Mar 28, 2011 | Whirlpool Freezers
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
My Whirlpool s20b RWW20 A/G has both indicator lights
that is not a problem all just have to do is just allow it to continue working.
Feb 15, 2010 | Freezers
I have whirpool fridge freezer american style and the temp lights flashing on and off wont turn off what can i be
Check the coil at the back of the freezer for ice buildup. Should there be ice build up, have it defrosted and cleaned. If that does not solve it check out the thermistor, also located at the back at a panel. It may have gone bad.
Nov 12, 2009 | Whirlpool Freezers
Whirlpool fridge freezer alarm s20D RSB33AG-B
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired.
Let me know
bb
Aug 31, 2009 | Whirlpool Freezers
I have a Whirlpool side by side fridge freezer (brand new only 2 days old) the alarm is going off and the two lines side by side on the freezer side are flashing?
The alarm is set off when the freezer is out of the differential range of the setpoint. In other words, the freezer is still too warm. If you press the alarm button, the sound will stop but the light will stay on. If the unit is working correctly and cooling properly, this light should go out once the cabinet temperature gets close to the setpoint temperature. Hope this helps you.
Mar 04, 2009 | Freezers
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
Whirlpool fridge freezer (american style)
you have a bad control or bad sensor
May 11, 2008 | Freezers
Freezers Logo
451 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
