Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Crushed ice option don't work properly . samsung RS2530B
New refrigerator. ice production is working fine. ice cube function working good. but when crushed ice function is selected it will dispense ice cubes. crushing don't seem to be working properly. . it did work fine the first couple of times .
trouble shooting says normal to get some crush ice when selectiong ice cube. but don't say anything if is the other way around.
need help.
thanks
  • 725 Answers
If it new call sears for service...with crushed ice the augar moter turn the other direction... it must not be turn the other way could be a switch in the control...
let me know for it help if NOT please let me know and I will be glad to do more in depth.
Posted on Sep 26, 2009
Why is my icemaker not chopping/Crushing Ice
If there are blades involved then they might be bent and/or need sharpening.
Jun 01, 2015 | Refrigerators
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
My Samsung RS267LBBP has stopped making cubed ice. It only crushe
try emptying your ice tray out cleaning it real good then try it if doesnt work still may need board or auger motor
Mar 18, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Ice dispensor only dispensing crushed ice - not cubed
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Dec 02, 2008 | GE GSH22JFT Side by Side Refrigerator
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice type won't change
If this is a mechanical unit, look for a bent or broken part. Electrical...this will likely also be a bent or broken part. Unplug before servicing this unit.
Nov 17, 2007 | Samsung RS2630SH Side by Side Refrigerator
Kitchenaid superba KSRG22FKSS01 Ice cube switch trouble
Since its an indoor ice maker its much harder to diagnose. However the motor is supposed to reverse for crushed/cubed so you can hold the freezer door switch and see if it does. If it doesnt reverse it could be the switch, or it could be a mechanical problem inside the blades (check for broken stationary blades)
Oct 18, 2007 | KitchenAid KSRS25IL Side by Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
829 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
