Question about HP DeskJet F380 All-In-One Printer
I can't get my HP DeskJet F300 series back online.I ve done everything, I ve even stopped the print spooler and started it again but the same problem still exists.And another problem that the ink cartidge light is flashing while it's a new one.I am using Ink 58 instead of 21, is this a problem?
    President:
  • 787 Answers
No, using Ink 58 instead of 21 is not a problem. Try to replace a color cartridge #22
Posted on Sep 30, 2009
  • cene765
    cene765 Sep 30, 2009
    MiAGon, don't confuse people. # 58 is photo cartridge and replace
    exactly the black cartridge # 21. # 58 have 3 colors - photo black, light cyan and light magenta.
    Problem Solver:
  • 19 Answers
First, the cartridges. This printer uses a 21 for Black and a 22 Tri-Color. The 58 is a Photo cartridge that replaces the 22, not the 21. Make sure that the cartridges are properly placed in the printer. The next step is the easier one. Might sound like some work, but it is the best way to correct conflicts with HP branded printers. First, uninstall the printer from the PC completely. Use the uninstall function. When that is done, re-install the printer onto the PC and test it. This should solve your problems, as long as there is not physical issues with the printer itself.
Posted on Sep 26, 2009
2 Suggested Answers
ViscamTech
  • 528 Answers
SOURCE: i have a deskjet F300 HP
Goto Start > Printers and Faxes.
See whether your printer is set as the default printer. (Default printer icon has a tick mark next to it).
Double-click the printer icon.
You will see a list of documents pending. Delete all the files. (Or select an item, and from document menu, click cancel. Do this for all the items).
Close this window.
Right-click the printer icon and see whether 'Pause printing' is ticked. If so, click it to remove the tick mark.
Restart the printer and the computer. (This is optional, but better to do it).
Now it will be OK.
Posted on Aug 12, 2009
HP Deskjet F300
When you click 'print' on your computer, change the printer-settings to "double-sided" or "print on both sides", and then click OK. The printer will do the rest.
Jan 07, 2014 | HP Deskjet F300 series
My Printer ( HP Deskjet F2210 ) will not print. It is installed, plugged in, and has ink AND paper. I've waited several hours for it to print but it will not work. It's stuck in the queque, or...
Go to START then RUN and type services.msc and click on OK. This should open services window. Scroll down to on the list and look for Print Spooler. Click on STOP on the left pane then restart the service. This should clear put the stuck document in your print spooler and you should be able to print again.
Hope this helps.
Jun 14, 2011 | HP Deskjet F2210 InkJet Printer
I have a HP printer on the front it sayd HP Deskjet F380 but on the back it had f300 all in one series with the model number beingQ8130A. i need a psu for this printer can u help?
HP Deskjet F380 falls under the F300 all in one series of HP Printers.
You need to contact your nearest HP dealer to buy a PSU for your printer. Or else contact HP Technical Support over phone for more info.
Feb 21, 2011 | HP Deskjet F300 series
My computer is saying that mt hp deskjet 380 is
You can try following steps.
1. Refresh the Spooler.
To refresh the spooler, Go to Start, and in start search box or Run, type services.msc and press enter.
Now Remove the USB cable from the back of the printer.
Now on Services window, search for Print Spooler.
once found,
Make a right click on it and select Stop
Then Again make a right click on it and select start.
Perform the steps Stop---start 3 times.
Once done, close the services window.
Then steps to be done on the printer.
Press the Power button for 30 seconds while the Power cable remains out.
Then insert the Power cable. And power ON the printer, if it does not Turn ON automatically.
If the issue still persists, please post back.
Apr 28, 2010 | HP DeskJet F380 All-In-One Printer
HP Deskjet F300 Series Offline
my print is offline, how can I fix?
Jun 08, 2009 | HP Office Equipment & Supplies
Can not print from computer to printer
hi,
try the following:
> start-->run, type services.msc
> double click on print spooler and click on stop and then click on start. press ok and close all the windows.
> unplug the usb cable from the printer
> now go to control panel and open printers and faxes.
> right click and delete all the printer icons related to hp deskjet f300 series.
> now plug the usb cable back to the printer
> wait for few minutes while it installs the driver automatically.
> thats it... now try printing
thanks and regards
agnel
Mar 15, 2008 | HP Deskjet F340 All-In-One Printer
Printer in error mode
Click Start - Control panel - Printers & FAXES
Right click on the printer icon Officejet 5600 series -- Select properties - Click on ports tab - Change the port to USB virtual port.
Disconnect the usb cable from the computer.
1. Click Start
2. Click Run
3. Type Services.msc
4. Locate print spooler on the list, right-click and choose stop.
5. Again right-click the print spooler and choose start.
Reconnect the usb cable try printing.
Thanks.
Dec 21, 2007 | HP DeskJet 5650 InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
681 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
