Question about LG WM-1832C Front Load Washer
Water is leaking from the door. Do I need to replace the door gasket?
  • 6,784 Answers
HI, first, make sure there isn't anything preventing the actual door seal from forming a complete seal around the door frame. this can be caused be a creased section of the seal, or a piece of debris. if the seal is free of the above stated issues, in should be replaced asap.
I would also inspect the door alignment as well. if the door is slightly mis-aligned, this will prevent the seal from making contact with the door frame in a appropriate manner, in return, causing a slight leak during the wash.
Posted on Sep 26, 2009
  • 61 Answers
Rotate the door seal
Posted on Sep 29, 2009
4 Suggested Answers
  • 61 Answers
SOURCE: Kenmore Elite HE3t door leaking (Model 44936)??
If the unit leaks during use with a constant drip from the 6 o'clock location between the seal and the glass on the door the solution is to change tha door seal. it is quite difficult to do I would recommend you call a local service company.
Posted on Dec 18, 2008
Jahn27
  • 1554 Answers
SOURCE: GE #WHDVH626 Front Loading Machine - Door gasket
Remove the top panel, the control panel, the toe panel, and the front panel to replace the door gasket. Disconnect power to the washer before servicing to avoid electric shock.
Remove the top panel by removing the top cover and the three 7-mm hex-head screws that attach the rear of the top panel to the cabinet. Remove the top cover by removing the three Phillips-head screws that hold it in place then insert a putty knife blade or similar tool along the top seam between the cover and the control panel. Lightly tap the cover off rearward; slide the top panel rearward then lift it off the cabinet.
Pull the dispenser drawer out until it stops; push down the locking tab, and then pull the dispenser drawer all the way out. Once the drawer is out, remove the Phillips-head screw from the recess of the drawer opening.
Remove the four Phillips-head screws that attach the control panel to the control panel cover. Release the tab on the right side of the control panel from the bracket inside the cabinet.
Lift the top edge of the control panel to release the three tabs that hold its top in place. Push the control panel towards the left, then release the side tab.
Label the wires and mark the connectors matching the wires before disconnecting the wires from the control panel.
Remove the three Phillips-head screws at the bottom of the toe panel holding it to the cabinet, then pull the toe panel down and off the cabinet.
Open the washer door, then remove the three Phillips-head screws holding the door switch and lock assembly to the front panel.
The door gasket is held to the lip of the door opening by a wire and a spring hidden in the fold of gasket. Grasp the wire at the spring location using a pair of needle-nose pliers and stretch the spring to clear the gasket, and then remove the wire and spring assembly. Peel off the door gasket from the lip of the door opening into the drum.
Remove the four Phillips-head screws that secure the front panel on its four corners to the cabinet. Lift up the front panel then remove it from the two hooks and all the way off the cabinet.
Pull down the top of the gasket, and then remove the nozzle from the gasket. Remove the gasket from the water inlet pipe, and then loosen the 7-mm bolt that tightens the wire holding the gasket to the outer tub lip. Take note of the position of the gasket, and then remove it and the wire from the lip of the outer tub.
Install the new gasket into the lip of the outer tub aligning the notch in the gasket with the arrow located on the top of the lip of the outer tub, and then secure it with the wire and the bolt. Do not over tighten the wire with the bolt. Allow a gap of about 1.25 inches between the ends of the wire. Over tightening the wire may tear the gasket.
Insert the nozzle into the gasket ensuring that the washer is placed on the outside and that the nozzle is aligned with the dent on the inside of the gasket. Insert the water inlet pipe into the gasket, and then put the gasket inside the drum.
Reinstall the front panel back into position on the hooks then secure it to the cabinet with the four Phillips-head screws.
Slide the toe panel up into the cabinet then secure it with the three Phillips-head screws.
Reconnect the wires to the control panel. Snap the control panel back into the cabinet, and then secure it with the screw at the recess of the drawer opening.
Slide the top panel back in place then secure its rear with the three 7mm hex-head screws to the cabinet. Reinstall the top cover and secure it the three Phillips-head screws.
Posted on Mar 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Door leak
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Ice is wet when it come through.
Hey RO, I appreciate your inquiry!
Based off the information you have provided the ice coming from your Frigidaire refrigerator is wet when it comes out. The wet ice could be due to a water leak within the icemaker or an air leak within the gasket. Is there any visible water leak from the icemaker?
I would also suggest checking the door gasket and you can use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the freezer. Hopefully this information is helpful to you. -Matt
Jan 31, 2016 | Frigidaire Refrigerators
Dishwasher leaking water
Either you have a failed gasket or a door out of adjustment.
Here's how you check the gasket.
Look at the gasket and see if there is a part that is ripped or has a hole in it.
You would then need to replace it.
Here's how to check the door adjustment.
Find some notebook paper, and close the door on the paper.
The paper should pull medium hard to get it out.
If the paper pulls out easily ( for example: on the bottom of the door) the door is out of adjustment.
You will be needing to take it apart and find out why.
It may be bent, or broken, or just worn out.
If the paper pulls out easily, and you are not in a position to replace the gasket now, you might at least consider that you could add a piece of stick-on gasket to build the door gasket up so it did not leak.
Some hardware stores sell stick-on gasket by the roll. You could try it.
Be blessed.
Mar 15, 2013 | Neff Dishwashers
Rear Door seal water leak
If silicon is working,I would go with it,silicone last a long time and it's working.
Dec 25, 2012 | 2001 Toyota Sienna
Leak at the bottom right hand corner of the dishwasher, I cleaned the gaskets, checked the door latch, checked the levelness, & the door hinge. Ran it thru the cycle & still leaks. How do you...
The gasket should pull rigth out. For the old gasket you can pull out with pliers. Once the first part is removed the rest is easier. Replace with similar one. Insert new gasket fully in groove. Remember that the first time the gasket will leak because it needs to expand. Also if you haven't used washer in a while it will leak becasue the gasket contracted.
Also with the power off check for water leaks at the inlet and outlet hoses and where it connects with the washer. Take a flashlight and dry finger and trace the water back to its source as muchs as possible.
Aug 17, 2010 | Frigidaire GLTF2940ES Front Load Washer
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
Leak in the drainage pan under frige
1. Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
2. Step 2 Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets
3. Step 3 If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls.
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Check out this link, its a video shows you how to fix a leaking fridge.
Apr 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Washer is overfilling
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jan 25, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Brand new dishwasher installed and water leaks out bottom of door
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Leaking water on floor in front of dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
LG WM-1832C Front Load Washer Logo
607 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
