Question about Panasonic PT-53WX42 53" Rear Projection Television
The picture has a multiple image recently - Panasonic PT-53WX42 53" Rear Projection Television
  • Panasonic Master
  • 3,459 Answers
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Sep 27, 2009
Picture scrambled / multiple pictures
CONVERGENCE PROBLEM. FIND A HONEST TV TECH. MAYBE A $300 REPAIR
Nov 11, 2013 | Sony KP-61S70 61" Rear Projection...
I want to copy multiple photos on A4 size paper on our Canon MG5150 printer. Is this possible and how do I change the setting as our printer we purchased from office works came with no mannual
i guess you are trying to print multiple images in one A4 sheet....
the best solution is to insert the images in MS Word....guess you know how to insert images in MS Word (tools / or / insert / picture or image)
select the images one by one...and resize it there to fit them in the A4 sheet....
guess this helps
Reg
Suresh
www.sureshayyar.110mb.com
Apr 28, 2011 | Office Equipment & Supplies
How do you delete multiple images from camera?
Are the pictures on a memory card? In that case, you're much better off formatting the card. If you continue to delete unwanted pictures, you'll fragment the card and ultimately you'll have problems. Every day somebody posts here with that problem. Formatting cleans things up.
If the pictures are in internal memory, select Internal Memory Tool from the Setup menu, and you can format the internal memory, deleting all the pictures. My earlier comments hold true here as well.
If you insist on keeping some pictures and deleting others, then go into the index (thumbnail) mode. Press the trashcan button, then select [Select] with up/down, then press *. Select images with the arrows, then press * to display the delete indicator on the selected pictures, Press the trashcan, select [OK], then press *.
May 13, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Multiple images on the test.
The multiple images were probably selected from your 'Video Effect' menu
Launch the logitech toolbar
Click the "Quick capture" ( 2 reel clips picture ) on the toolbar to start your webcam and test your drivers are working ok
If you have muliple images, keep the webcam running and click on the video effects ( 2 theatre masks ). Ensure no effects are selected and finally trim the image by selecting 'Settings' ( 2 gear wheels ) and fine tune your image. Use the Advanced tab to change the mirror images if necessary
Dec 13, 2009 | Logitech Webcam
Delete multiple pictures
The only way you can delete multiple pictures with this camera is to use the format function. This deletes all information including pictures and video from the card giving a totally blank card. You can set it to do this with internal memory also.
There is no function to selectively pick multiple images for deletion.
Hope this helps. Please remember to rate my answer. Many Thanks.
Jul 07, 2009 | Kodak Easyshare C813 Digital Camera
Rcs hdtv multiple images
The problem you're having is due to the failure of the convergence amplifier circuit. In that circuit are some components which amplify or control the signals to the dynamic convergence yokes, which line up the red green and blue images to superimpose them over each other to create a proper colour picture. When you get a failure in that circuit, it no longer aligns the images properly, and generally you get what appears to be badly set geometry in multiple colours. In some cases you will also get a problem with the part of the power supply that supplies the convergence amplifiers, or the digicon, which is the digital convergence control module.
Jun 12, 2009 | Hitachi 43FDX01B TV
Multiple vertical color lines,i take the picture,how can i send you this photo?
There are two ways you can do this.
1. post the image to a site like photo bucket or flicker and post the link here
2. next to the You Tube on the top of the post reply window click the image. This will open a window. Browse to where you have the image saved and click it. This will insert the image to your reply.
Jun 02, 2009 | Acer 22" X223w LCD Monitor
GHOST/MULTIPLE IMAGES AND COLORS ON MITSUBISHI WS55807 PROJECTION TV
In the menu ,,under settings usally ther a convergenge option,,what it does is realine the colors,, that should do the trick,,if your tv has that ,,good luck
Oct 05, 2008 | Mitsubishi WS-55807 TV
PJ458D Displays Multiple Lines and scrambled picture
White noise-the image you get when you turn your television to a channel that isn't receiving a signal. Sorry, this is an old term for on-air televisions. Its kinda the same image you get when your DirecTV signal gets scrambled during a thunderstorm.
Sep 20, 2008 | ViewSonic PJ458D Multimedia Projector
Multiple Images, colors separated
your convergence ICs are needing to be replaced. i can post a link where you can order replacement ICs and they provide free step by step instructions with pictures so you can do the repair yourself saving at least 300.00. let me know if you would like the link.
Apr 03, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
101 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
