It's best if you use the "reply to post" window below the solution box so you can continue the same thread with the same person.
To set up the restriction filters we'll need to get into programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key (bottom right arrow).
The display should now LINES.
Press the show key (top right arrow)
The display should now ask for a line number.
Enter line number you want to change the line filter on. ex. 002 = line 2
The display should say Trunk/Line data
Press the next key 2 times (bottom right arrow) .
The display should say Restrictions.
The display should say Restriction Filters
Enter in the restriction filter 25
The display should say No Restrictions and the ADD soft key should appear on the lower right soft key
Press the add soft key and in the restrictions you want on the line.ex. 011any will bolck int'l dialing but not long distance. 0any and 1any will block long distance, operator assisted calls, and int'l dialing
You can also add overrides by pressing the show key (top right arrow) then the next key (bottom right arrow) .The display should say no over rides and the add soft key should appear on the right soft key.
When finished with the filter press the heading key(top left arrow)
Press the next key (bottom right arrow) .
The display should say Line restrictions
The display should say Normal:none
Press the change key and enter 25.
Press the heading key (top left arrow) til the display says Lines.
Press the back key (bottom left arrow)
The display should say Terminals&Sets
Enter in the extension number of the person you want to allow free use of the line.
Press the next key 4 times(bottom right key)
Press the next key 2 times(bottom right arrow)
The display should say Line/Set restrictions
The display should ask for a line number.
Enter in the number of the line that was restricted.
The display should say Normal: none
Change the filter to 00 (no restrictions)
That bypasses this extension from line filter 25
Press the release key when finished
