Question about Mtd Garden
MTD yard machine model 668 (46in) does not engage
MTD yard model 668 (46in) only moves in hi (5/6) gear. Unit can not be pushed or moved in neutral either. Belts are intact, runs fine otherwise. Any suggestions?
    Champion:
  • 205 Answers
Check your brake pins on the trany there rusted and sticking. you can also shoot some wd-40 and hit your bake pedal till ti comes loss. now if you still can't use low dear check your variable speed pulley assay. may need to be replaced or rusted too. check for missing spring too. adjustment may be needed
Posted on Oct 14, 2009
I have a model 600-699 1998 MTD 46in YARD MACHINE. Is it possible to check/add fluid to the trans axle?
I had a 1999 yard machine that did the same thing i had to replace the transmission it was still working when i sold it this year
Sep 04, 2017 | Mtd Garden
My 95 yard machine stays engaged in gear while pushed in or even in park
Outdoor Power Equipment Parts Use the Part Finder Tool from MTD and it will, the variable pulleys and belts need to be uncoupled, maybe try depressing the pedal a little (ON FLAT GROUND) park brake disengaged.
Aug 05, 2013 | Yard Machines MTD Gold 185 HP Lawn Tractor...
I have a Yard-Man MTD lawn tractor model # 13AN604G501. My problem is that when I engage the machine to drive, it pulses, as felt on the peddle below the brake, while driving. (the peddle pushes against...
I would start by inspecting the belts,may be too tight.Then move to the fuel system.I also would make sure the throttle cable does not have a problem.If all that looks good I would clean the carb next.
May 20, 2011 | Mtd Garden
I have a snow blower which will start up but it won't move forward in the snow nor will it push the snow. Not sure what is wrong. I can manually move the blade around that pushes the snow.
If you start the machine and the axles spin but the augers do not it is because the shear pins are broke. If you look closely you will see the the augers have shear bolts and nuts or shear pins. If you jam a piece of ice or a stick in the augers while they are spinning the bolts will shear so you do not damage the expensive augers or the worm drive gears. If the axle spins with the augers you may have torn up the front worm gear in the front of the auger intake. If you spin the small auger and the large auger moves but when you start and engage the auger nothing happens you will have to remove the under cover and inspect the drive belt pulleys for jammed or broken parts or more commonly broken drive belts.
Jan 28, 2011 | Mtd 22" Yard Machine Push Mower
Starts fine but quits when you move it
do you mean it cuts out when the drive is engaged? if so check the drive belt isnt stuck or the gearbox hasnt seized
Aug 19, 2010 | Mtd 22" Yard Machine Push Mower
Thee is no serial or model no. plate on my mtd yard machine tiller. I need a diagram of the gear mechanism, when I split it apart all the gears a nd chain fell out.
Had the same problem with my MTD Yard Machines 5 horse tiller. I called MTD at 800-800-7310 and with the model and serial and such off the engine - which are stamped into it - a nice lady was able to narrow down my tiller year. From there with horsepower details she narrowed further to one of two models that I could look up on the MTD corporate home page and get a schematic.
Hope that helps.
Jun 17, 2010 | Mtd Products Yard Machines 158CC Tiller
My Yardsman Snowthrower will not move when it is put in gear.
My old machine just did the same thing. When I lift the unit off the wheels with the gear engaged the wheels move. when I put it down the machine doesn't move. This happened while I was using the machine. BTW the machine is 20 years old.
Dec 31, 2009 | Mtd Products Yard Machines 158CC Tiller
My 2000 / 2001 17HP Yard Machine won't start. Battery and plug OK
It could be a burned fuse!
Locate the wiring harness at the back of the ignition switch and follow it until you locate the in-line fuse. Remove the fuse and check it. It should be a 20 amp fuse.
Sep 19, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
Apr 22, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
359 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
