Question about Fuji FinePix Z10fd Digital Camera
"protected card" sign
When i open the camera, a "protected card" sign appears. i'm not able to take pictures or get to the menu. how do i fix it?
    Brigadier General:
  • 11,967 Answers
Check the slide switch on the side of the card.
Posted on Sep 26, 2009
How do I delete all photos on my chip
Based on what you have said, it appears that the write-protect has been activated on the card. With the card's label facing you and the corner cut-off to the right, you'll see a little slot just a bit above the halfway point on the card. In that slot is a tab. If the tab is down toward the bottom of the card, it's in the write-protect or locked position. You cannot delete anything while the card is in the write-protect mode. Simply slide the tab to the top of the slot to unlock it and your delete function should work.
If it does not, you've got another problem which you may be able to fix by formatting the card. Once again, you cannot format a card in the write-protected mode.
If you can't format it...which will delete any pictures on the card... then the card is probably bad and should be replaced. Cards are cheap and really not worth spending a lot of time trying to solve the problem.
If you can't format a new card, then you've got a camera problem and it's time to call or contact Nikon support.
Feb 12, 2015 | Nikon D5000 Digital Camera
My camera says Write Protect! And my memory card is unlocked..it appeared when i was uploading pictures and all of a sudden `write protected`appreared and I cannot use my camera or take any photos...w
Have you tried a new memory card,or reformatted the existing one?
Or go on the menu on the camera and restore all the original factory settings?
If none of those work it might be time for a new camera!
Mar 23, 2014 | Olympus Tough TG-310 Digital Camera - Red...
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
My Fujifilm 10.2 Mega Pixcels camera zoom lense has jammed in the out position, and the camera appears to be dead. Removing the memory and batteries does not fix.
my camera is saying protected memory card and i need help fixing it. i can't do anything with the camera besides look at the pictures on the card. i can't take pictures or access the menu features.
Nov 24, 2010 | Fuji FinePix Digital Camera
My picture card is saying no picture when i go to take a picture the card says full it wont let me take a picture??
Hi.
Check AE lock custom button:
Ensure that the memory card has no protective seal or object in front of the protection area. See here.
Ensure that the files are not individually protected (Key sign in settings)
If that does not fix the problem, then the card may be defective. In that case replace the card.
Here a manual.
Sep 14, 2010 | Olympus Camedia C-3020 Zoom Digital Camera
HOW DO I UNLOCK PROTECTED PICTURES IN MY CAMERA
Press MENU to enter the menu. Select the SETUP menu (the wrench icon). Select Protect (the key icon). Protected pictures are indicated by a little key icon in the upper-left corner of the picture. Navigate to the protected ones and press up/down to unprotect.
Or is the entire card protected? SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 17, 2010 | Nikon COOLPIX L18 Digital Camera
Every time I turn on my camera a message appears on the screen that says "write protect". What is "write protect" and how do I get rid of the message?
1) It could be your camera has write protect switched on. Go through your camera's menu and look for picture protect and remove it.
2) Your SD card could be write protected. Take out the SD card and check, there's probably a sliding notch on the left hand side, move the to write enable.
Jun 27, 2010 | Olympus FE-190 Digital Camera
Pictures were taken with my SONY CYBERSHOT 10.1 camera - but there was no memory stick in the camera. Now the picture are in the internal memory. I've tried to delete them, but I get messages that say they...
first of all remove any memory card you may have in the camera.. Then connect the camera to your computer using the USB cable provided. Then Switch on the camera, Once windows has recognised your camera, open up My Computer. There will be a removable disk icon appeared, open it up. Open the DCIM folder, then open the 101_SONY folder. This now has given you access the area where the camera stores you photos. select the first file by left clicking on it, then hold shift and left click on the last file, they should all now be highlighted. Now right click on the last file. and select properties from the menu. On the window that appears, deselect read-only checkbox and click Apply. Your photos will now no longer be write protected and can be deleted.
Hope this helps
Jun 05, 2010 | Sony Cybershot DSC-T77 Digital Camera
Can't take photos as it says card protected. I don't know how to unprotect it?
There are 2 protection that you have to check:
1) Check on your SD Memory card that on the side there is a small switch. Move it to the opposite position and reinsert in the camera. Take a picture and see if it is OK.
2) If still appearing the message go in the PLAY menu of the camera and where there is the entry PROTECT with a Key Logo select NO.
Then it should be working fine.
Remember that then your pictures are not protected anymore.
Regards,
PDG
May 09, 2010 | Fuji FinePix S1000FD Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
