Question about HP Compaq Presario FP7317 17" LCD Monitor
How do I reinstall Sonic Update Manager? I uninstalled some things trying to make my computer faster, & may have accidentally uninstalled this, a little box pops up every time I turn on the computer.
  • 403 Answers
What I would recommend to you at this point is to go to your system restore and restore to the point before you made these changes. Go to your windows back up and always make a back up before you make changes. The biggest problem with programs today is that when you install them the associate themselves to other programs in your registry. What program are you using to uninstall them. Make sure you use a program and do not uninstall programs by files. Let me know if this helps or if I can help you further.
JimmyC
Posted on Sep 26, 2009
I accidentally uninstalled my ethernet controller.
start > right click on My Computer > click on device manager > update the driver on Ethernet. good luck.
Mar 16, 2014 | Computers & Internet
SONIC UPDATE MANAGER & ALOT
It seems that the Sonic update manager is updating automatically or popping up while booting the computer.
This may be caused by removing certain non-Sonic/Roxio applications that share file resources with our Sonic/Roxio software. To resolve, it is required to replace these files with a fix utility.
It is not required to reinstall this application entirely.
It is just required to run this fix utility and reboot the computer.
Note: close all applications regarding Sonic and Roxio before installing.
Source of Fix file: http://tools.roxio.com/support/dell/isum_hotfix.exe
May 28, 2011 | Computers & Internet
I have updated v1.2 patch and game not opennig <Error Msg> The specified node path: TbBankBalanceValue could not be found. <Call Stack> Empty
Hello
Completly uninstall the whole game,and any folders related to it delete.
Then reinstall.
Once done delete your update,and redownload then reinstall.
Possible, update is missing files or corrupt.Which may have corrupted the core game.
Mar 22, 2011 | EA - Electronic Arts FIFA Manager 2006 for...
Its not picking up the sat harddrive or the cd drive
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall as for sata hard drive
control panel admistrive tools,computer management,device manager scroll cd/dvd rom drives right click you can update driver disable or uninstall select properties from there you can troubleshoot or select driver you can update roll back driver uninstall if at any time you see a yellow question mark? you need to install a driver
hope this helps
Oct 23, 2010 | Asrock K7VT4A-Pro Motherboard
either uninstall sonic or
uncheck the sonic software in MSconfig
MSconfig
goto Start-Run-type msconfig
click on Startup tab
unclick any reference to sonic software
reboot
Oct 09, 2009 | Computers & Internet
CAN'T INSTALL WINDOWS SERVICE PACK 3 (KB936929) and SONIC UPDATE MANAGER
All you need to do is open sonic update and disable sonic update manager from running automatically.Then reinstall the updates.
May 16, 2009 | Dell Precision 380 P4 Dual Core 3 GHz...
Roxio update manager cannot find Um.msi
I found this...may be helpful...
Usually, a "UM.MSI" error means that the update manager may have become corrupted and needs to be reinstalled
To resolve :
> Permanently remove the Sonic Update Manager. This will not affect the performance of any Sonic/Roxio software currently installed on the system.
> Reinstall the application.if any errors while installing then install the fix.
> This may be caused by removing certain non-Sonic/Roxio applications that share file resources with our Sonic/Roxio software. To fix, you will need to replace these files with this fix utility: http://tools.roxio.com/support/dell/isum_hotfix.exe
> Be sure all Sonic and Roxio applications are shut down before launching this utility. This hotfix requires a reboot. No reinstallation of the software is necessary.
Apr 19, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
A pop up refuses to be deleted (SONIC UPDATE MANAGER) Its not been asked for. trys to stop me logging on and off
What you can try is going into your add/remove programs in the control panel and looking for that program and uninstalling it. That program is no good and should be removed immediately. I have had numerous customers come to my business and have the same problem and once they did that their computer has been just fine! If you have any other questions please feel free to let me know!
Apr 08, 2009 | Computers & Internet
A pop up.refuses to be deleated its called (sonic update manager) It has not been asked for & messes up logging in & logging out.
This pop up is because Sonic update Manager is running in the background. If you don't use Sonic then uninstall it else if you want to keep Sonic but get rid of this pop-up then
click on start --> Run --> type msconfig in the run box
Go to Services tab and first check the bottom check box that says "Hide all Microsoft services" then go through the list and see if you can find anything that matches the description of Sonic update Manager and uncheck it.
Click on the Startup tab and uncheck the items that match the sonic description.
Apply the changes and the computer would ask you to reboot to apply the changes, reboot the computer.
Let me know if you still face issues after that.
Please rate the solution
Regards,
Srinivas
Sonic Record Now
Try to restore your machine a day before!!!
Sep 23, 2007 | Sonic RecordNow! Deluxe 7.3
HP Compaq Presario FP7317 17" LCD Monitor Logo
160 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
