Question about Kenmore Dryers
My dryer won't turn on
Series 70 MOD 110.68712894
SERIAL # MJ2560323
TYPE DWJR-ELE-2406028-FM54
120/240 V 28A 60 Hz
Could it be a bad fuse or something else?
Thanks for your help
  • Kenmore Master
  • 7,482 Answers
Make sure that the problem is not a broken belt, or a belt that has slipped off of the motor pulley or idle arm pulley.
Look to see if the motor is running first, sometimes you cannot hear the motor running but it is.
Also you can check your breakers to see if one is kicked out.
This problem can also be caused by a faulty start switch.
If this is not the problem than it may be time to call the repairman
Posted on Sep 26, 2009
Motor wouldn't start replaced the motor and it still won't start?
Did you replace the thermal limiter fuse inside the cabinet near the motor? It is likely burned out. Contact the repairclinic.com for the part or Sears.
Jan 19, 2012 | Whirlpool Dryers
I have a Kenmore Dryer it works but will not tumble i'ts a heavy dudy super capacity 70 series modle 110-64742400 you may need this to dwjr-ele-2406028-fm54
When the drum won't turn and the dryer is otherwise working it's usually due to a broken belt. Open the front of the machine to inspect the belt.
  1. Under the lint door remove 2 screws
  2. Use flathead screwdriver to pry up the top lid
  3. In the middle of the drum should appear a belt, if you see it, pull on it. If it is loose it's fallen off the belt tensioner. If there's no belt of if the belt breaks in your hands, you need a new belt.
A sample of the typical belt routing for your machine is available at the link below:
Kenmore Dryer Belt routing
Sep 08, 2011 | 2007 Toyota Camry
Have a Kenmore Elite Dryer that won't start. Mod 110.65962401 Ser MS0303258 Type DDOT-ELE-2406028-CV54
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Electric Dryer , 700 series, MOD 64722400 , SER MR4136705 , Type DWJR-ELE-2406028-FM64 . Dryer is not heating, checked fuse it's fine, cleaned every nook and cranny with a swifter duster and...
Hi.
Be sure that you have checked the thermal fuse. The part is tested using a multimeter set on Ohms (impedance). Remove the fuse from dryer and read impedance touching the fuse contacts with the two multimeter probes. If impedance is Ohm infinity (open), then the fuse is bad.
If the fuse is OK because tested good or replaced, then the problem is either one of the three thermostats located in the heating group, or the heating element. All parts are tested similarly to what described for the thermal fuse. If any of the parts read open (infinity), then the part is faulty. After finding the defective part remove all the lint from heating assembly and air duct. The lint causes overheating and blows thermostats, fuse or element.
Regards.
Ginko
Jul 14, 2011 | Kenmore 64722 Electric Dryer
I have a Kenmore Series 70 Dryer. It starts but runs constanly never shutting off and not getting hot. Model number 110.62702181 Serial number MM0609310 Type DWSR-ELE-2406028- FM54
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 13, 2010 | Dryers
Where do you find a heating element for a Kenmore Model #110.66662500. Serial: MT0203728 Type: DWJR-ELE-2406028-FM54
Grainger.com is easy or you can look thru the yellow pages for a local appliance repair store, for parts.
Nov 10, 2009 | Kenmore 62602 Electric Dryer
It appears the heating element went out on our older Kenmore dryer - Type DWJR ELE 2406028 FM54. mod 110.62622101. Is this an easy fix?
Yes it is fairly easy to replace from the back. First verify it is the element and not the thermal fuse or a loss of one leg of the 240VAC circuit.
Eric
Jul 06, 2009 | Dryers
Kenmore electric dryer Mod. 100.66662501, type dwjr-ele-2406028-fm54 Dryer blew fuses, so we replaced the fuses. Dryer then ran about 10 minute, was heating fine but then blew the fuses again. Help!
Assuming that the fuses you speak of are the external pair, and not the internal motor or timer resets:
Check the fuse holder for corrosion on the plates. Often the fuse is not properly seated because of this build-up and therefore has an intermittent connection. This will cause the fuse to either heat up, or overload; ultimately failing.
To remedy this, turn OFF the breaker, or main switch if necessary, and fix a wooden dowel with a piece of emery cloth (or sand paper) on the end. Remove any visible black corrosion from the contact plates.
Finish with a spray of WD40 to protect the plates and fuse end.
Replace the fuse, ensuring that it's tight, reinstate power and try again.
Was this  helpful?
May 13, 2009 | Kenmore Dryers
Dryer runs no heat
Sounds to me you either blew the fuse or tripped the circuit for the heating element. Try replacing the fuse or resetting the breaker before trying any repairs.
Jan 09, 2009 | Kenmore 64602 Electric Dryer
Dryers Logo
213 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
