Question about Car Audio & Video
1996 vw jetta arms its security system by itself. i want to disable it si can drive without disconnecting the battery and waiting 30 minutes. does anyone know how? maybe disconnecting a wire?
  • 615 Answers
See check for fuse outside or in the fuse box, this is the fastest way, and let me know, please see that grant me your approvals by rating my service and I hope that I can serve you again the future. I will work with you in this issue to conclusion
Posted on Sep 26, 2009
My 2001 vw jetta, i think i hit the panic button as i was turning the key to start the car...the alarm went off and hitting the unlock button does not shut it off (the alarm) i cant get the key out of the...
I think unrelated problems, rock steering wheel and try to remove key, perhaps put vehicle in park the drive a few times wouldn't hurt. Then I would disconnect the battery for a few minutes so the security system will reset itself and see if that solves problem.
Nov 30, 2013 | Volkswagen Jetta Cars & Trucks
Is there a way to disarm the alarm system in the 1996 vw jetta? I'm having a lot of trouble with the alarm light staying on after I turn off the engine and take out the key. Then the light won't go off...
In a word NO,without totally destroying the computerised ignition system.only way is to use the remotes to arm/disarm the system(if you havnt got them you will NEED to buy them and get them coded to the car.takes 30 minites max.to reset see my jetta hints......
Jan 26, 2011 | 1996 Volkswagen Jetta
How do you reset the timing on a 1998 VW Jetta?
a car of that year should have an ecu controlling fuel air mix etc. this normally controls the timing.
To reset the ecu on my '95 VW Golf disconnect the battery (negative / black terminal) for 15-30 minutes depending on who you ask. So I do 30 minutes.
If it has central locking make sure you don't leave the keys in the car when reconnect it. swich on the ignition without starting the engine so the dash lights up with the oil light etc. for 30 seconds then off for 10 seconds. then start your car. It will relearn so it will run a bit rough for a while but should settle down. take it for a spin on different types of road ie. slow and fast.
Nov 22, 2010 | 1998 Volkswagen Jetta
1997 jetta will not start. the battery has been disconnected and charged. Is it true that when the power has been disconnected that there are some security steps to go through before the car can be...
all vw MUST be reset after battery dies/changed.put key in door,unlock/hold key over 30 secs(windows go down)then lock/hold key over 30 secs(windows go up/sunroof closes)then press unlock button on remote for 30 secs......RESET DONE......(try this for fun....sit in car after turning off engine/remove key,drivers door keypad is still live(until you open door)ALSO when engine is running lower any window and then raise up with fingers in top of door,the window will rollback.(if you do it once it hurts..twice it really hurts..three times it traps your hand in.)ALL THIS is NOT in the handbook.......
Nov 06, 2010 | 1997 Volkswagen Jetta
I have a 1996 volkswagon jetta and I removed the thermostat but the temperature guage is still going pass half. Is there anyway to get the air out of the system and solve this overheating problem?
hallo
without termostat, start the car. in one minute ideling, both hoses from cooller should be warm.
If only top one is warm, check if the hose from front wather cooller to expansion tank is blocked (small one on top). usualy it is blocked on wather cooller itself .if OK, change wather pump.
also check if presure is bildinh inside wather sistem. that indicate head gasket or head itself should be checked
If you had remove the termostat, there can be no air inside the engine (if wather is inside).Even with termostat present, VW has no problem with air pockets.If your temp.go pass half when car is standing still, that is ok, but when driving must drop down.
Marko
Sep 23, 2009 | 1996 Volkswagen Jetta
1996 VW Jetta wont start
Check to see if it's getting gas or spray some starter fluid into intake. If it fires, change fuel filter first and try it without starter fluid. If it doesn't start then change fuel pump.
Jul 01, 2009 | 1996 Volkswagen Jetta
How do you reset a low tire pressure warning on a 2008 Jetta?
#1 Make sure the tires are at the proper press and drive it for approx 10 - 15 minutes or disconnect the
battery for about 30 minutes (just don't do that if you have to get the emissions done soon, within 2 weeks or so you will not have enough memory to pass).
Apr 19, 2009 | 2008 Volkswagen Jetta
2003 VW Jetta TDI Check Engine Light Issue
Try disconnecting the battery (unhook on of the terminals) wait for like 15 mins, hook the terminal once again and start the car. I also own a 2003 Jetta and once my engine light would come on after 2 mins of driving. Disconnecting the battery is like resetting the computer and hopefully the sensor.
Apr 09, 2009 | 2003 Volkswagen Jetta TDI
Factory security system
I had an aftermarket alarm on a Wrangler and encountered the same problem. With the car off I disconnected the battery, then pulled the fuse(s) for the alarm. I waited to reconnect the battery for about 10 minutes because the computer can hold memory with no power source for a short amount of time. (I did not put the alarm fuses back in.) This disables the alarm, but atleast the Jeep started.
Nov 22, 2008 | 1996 Jeep Grand Cherokee
Car Audio & Video Logo
13 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
