Question about ASUS (90-N801G1100) CD-RW/DVD-ROM (Combo) Burner
I have an asus eeepc and I have just purchased a my-link external disk drive.. i have connected via usb port.. what do i do now...? Sorry new to computers please use basic english
    Guru:
  • 689 Answers
Only certain models auto-cofigure,refer to manufacturers site/book to find out which one to buy with the least hassel and guaranteed configuration
Posted on Sep 04, 2010
Asus eee pc 900 netbook will not boot. Error message says remove disks or other media press any key to restart
Hi guys, i hope this could bring little light to this boot-stop error. First of all sorry for my english /slovakia/. So thi applies for asus eeepc 1005HA /maybe some other models too - depending on motherboard construction. In my case it was 2 parts motherboard which were conected via flex cable. Both parts contrains USB ports which is the think what stops you access to BIOS and all functions. If you hit TAB button during start up /best way to do so before pressing powerbutton/ you will see post messages, which stops on inicializing USB controlers. So what you need to do is
1. turn on computer
2.unplug flex cable which leds to usb ports
3. now you should see progress on your screen, so go to BIOS /F2/
4. visit ADVANCE tab
5. visit ide onboard configuration
6. check for usb controler configuration
7. mark it as DISABLED
8. hit F10 to save your settings
9.reboot
after this hint you will have full access to all functions like before, USB ports included.
hope this little research hlep u too, my eee1005HA is now glowing
May 03, 2012 | ASUS Eee PC 900HD Netbook
Restore my laptop to factory settings
Hi well you can ONLY do this with an external USB connected DVD, or USB memory stick. You would need to use the DVD and Boot up off the EEEPC DVD that came with the PC, or download a copy from the net, and then simply follow instructions. The same applies to the USB drive, you would need to make a install disk, using the software and a PC.
http://www.youtube.com/watch?v=6tMnkhWXO5U
http://wiki.eeeuser.com/howto:usbrestore
http://www.linux23.com/torrent/eeepc-701-restore-discs:2e65698e76975d3cb4ee4259f2e5095f179feca4
above are links for how to do it the last link is to download the restore DVD
Oct 11, 2011 | ASUS Eee PC 701 Notebook
Dear sir, i have just purchased an asus m4n68-tm mother board with amd athlon ii x2 3.0ghz processor. im facing an strange problem. i have an external 320gb western digital hard disk. the problem is the...
Hi there, It sounds like your problem is that you haven't hooked up your front USB ports to your motherboard. If you open up your computer case, you should notice some cables coming down from the front USB ports. Those cables need to be attached to USB headers on your motherboard. You should check out your motherboards manual to see where the pins for the USB headers are, and then hook up the cable. My guess would be that no USB device works via the front panel, but after hooking up these cables all devices, including your external hard drive, will. If you need more help/clarification, let me know please! Alex
Jun 03, 2011 | ASUS M4N68TM Motherboard
Have an EeePC, then i cannot run cd-rom compact disk. EOTSQAAJ
You will either need to share a CD drive on another computer on the network, or purchase an external CD drive in order to install this from the CD.
Mar 08, 2011 | Arcsoft PhotoImpression 5
Where is Floppy Disc Drive A located on the PC?
This notebook does not have a floppy Disc drive, the CD or DVD drive performs the sme function
Jan 04, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Terabyte iomega hard drive, the two lights are flashing red, fan not operating, no access via My Computer.
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Nov 08, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have an asus epc 701sd netbook how do I rest to factory settings
Press and hold F9 at reboot...
if no response.. then you need to use the recovery DVD.. typically EEEPC models don't have a DVD drive and you will need to connect an external one via USB.. there is also workaround options to run recovery media directly through USB flash drives if you research more about that..
May 28, 2010 | ASUS Computers & Internet
I have an asus eeepc 900. i have an error message
hi charmed4031this netbook comes with an internal harddisk on which windows is installed but lacks any optical drives so far.
You will have to get an external CD/DVD-drive plus a Windows-CD for it from which you safely can reinstall windows or replace the missing file. Please find out which windows version you are using(Win200, Win XP Home for e.g.,), lend or buy this external drive, connect devices and let the computer work it's magic, if still facing diffifculties, you know where to find us ;-)
Sep 18, 2009 | ASUS Eee PC 900 16G Notebook
USB External Harddisk Detection Problem
some people say that its because of not enough power . try inserting the hard disk in other usb slots ( at the back ). onlu usb slots at the back of my pc detects my hard disk
Aug 06, 2009 | ASUS M2N-MX Motherboard
Can a WEbcam be installed
Most 701 models came with a web cam built in.
You can install an external one easily.. just plug it in to the usb port.
Previous poster is wrong... why would you need a Cd drive ?
You could either download the drivers from the webcam maker's website, or simply copy the file from the CD to a SD card with another computer. If you have a home network setup, you could simply copy the files via network file sharing.
If you have the linux version of the EeePC 701, then make sure you buy a compatible webcam that has drivers in linux.
Jun 19, 2008 | ASUS Eee 4G Notebook
ASUS (90-N801G1100) CD-RW/DVD-ROM (Combo) Burner Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
