I am still having problems with a Mitsubishi 60" projection TV Vs-6051. I know that the set is old and some of the codes and suggestions that I received do not work on this set. The chasis is VZ2. The values for all 52 of the color calibrations are off. Also, the screen is distorted. Any suggestions?
  • 11,896 Answers
All the IC's will have to be replaced or if you have the STK's, they should be replaced. A manual and tester would be a good idea to have. The convergance is off. If your model has a convergance board, you can get a capacitor tester and test the caps
Posted on Sep 26, 2009
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
I just wanted to know how much they go for. Mitsubishi big screen tv hd 1080 series model vs-60111
Probably 1500.00 new, but that's an old set. If your trying to sell it I would ask 350.00 for it, if it works.
Dec 18, 2009 | Mitsubishi VS-60111 60" Rear Projection...
The TV would periodically shut off, and not come back on for a while. It kept getting worse and worse, and now it wont turn on at all. You can hear a clicking sound when it shuts down. The TV is a...
Sounds like bad solder around the power supply or deflection circuits. take the back cover off and using something non conductive i.e a wooden salad spoon try knocking on some of the heatsinks and around the circuit if it reacts it may help you pinpoint the area of the problem. next you`ll need to pull out the circuit and solder the connections that look weak, they might have a ring like hairline crack around the solder joint. good luck and don`t forget to unplug before working on it.you dont want to end up with curly hairs
Nov 02, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi Big Screen TV Model VS-6051 will not turn on. I hear a clicking sound when I unplug it from the wall but it still does not turn on.I have tried using an alternative power source and it still...
hello VS6051 POWER SUPPLY PULSATES ON/OFF IC9A1(267P062010)
VS6051 VZ2 POOR START L9A30(BEAD ON LEG OF R9A21)-R9A22 TO 1.2K, R9A12 TO 15K,C9A15 TO 330UF
VS6051 VZ2 POOR START,ADD 22UF/100V PARALLEL W/C9A17
VS6051 VZ2 WILL NOT POWER ON D9A00(264P102020) IC9A0(267P112050)
Sep 19, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Have a bow in the top of the screen for a Mitsubishi vs-6051
Call a good TV Tech and tell him the problem is the convergence amp IC's are bad and need replacing. This should not cost over $325
Jul 28, 2009 | Mitsubishi VS-6055 60" Rear Projection...
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
VS-6051 fuzzy picture
Those three Knobs were the focus or screen controls . your problem may be dust and dirt on the lens or the tubes could be getting soft. It could also be a convergence trouble and thats very common in these sets . a picture would be nice see where your problem lies BUT let me warm you down there where you were plying and turning those little knobs is about 32000 volts!!did you know this ? A tv set is not something to experiment with as it could kill ya. Unless you have technical background in electronics I would call a servicer to assist you. Good Luck
May 26, 2006 | Mitsubishi VS-6055 60" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
