Question about Dryers
New dryer not heating people said they replaced pig tail
  • Anonymous Mar 16, 2014
    i put a new pig tail on dryer and now i cant get it started
  • 1,531 Answers
If they dryer is running and you have no heat make sure that you have the correct power to the unit .if so it most likely is a bad thermal fuse.those are the first to check then check the heating element.
Posted on Sep 26, 2009
  • 403 Answers
What I do with new dryers are to use the warranty as long as you can. If it does not work make them fix it. In order to see if the unit is working properly it has to run through several times. Whirlpool dryers have problems with their boards. Could be a faulty element. So many things as it is new. With older units it's easier to locate. Think of your unit like new cars today, they make them so hard to work on. You almost always have to take it to the dealer. Let me know the model as I can give you more information. Hope this helps.
JimmyC
Want to replace tail light for a 2001 golf 1 with the new round tail light, the plugs or wiring is not the same, please help
well you can go to a auto parts place , they most times have racks with different types of pig tails for different cars, or a U=Pick auto wrecker place. All you have to do soldier on new pig tails
Oct 02, 2013 | Cars & Trucks
Dryer wont heat up
Is the circuit breaker a duel bullet type fuse (2) in the case for the 220 line? Try changing them and see what happens.
Apr 07, 2013 | Dryers
Electric dryer heats up and trips breaker
you need to turn the power off to the dryer outlet then to make sure it is off try turn on dryer if it doesn't turn on you may now unplug dryer and remove screw in the center of the outlet then check to make sure all wires are tight if they are then you need to check the wires on the dryers plug "the pig tail" make sure they are tight.If all are tight then you have a problem internally and should contact a repair professional.
May 06, 2012 | Whirlpool Dryers
Changing pig tail from three prong to 4 prong on maytag dryer where do i put the red black white and green wires on the pig tail connection on the dryer
the red black and white wire go in the same place as the other wires and the green wire gets screwed to the green ground screw.
the white wire goes in the middle red to the left and black to the right.or just look att he wires and match them
Mar 09, 2010 | Dryers
My dryer runs, but it does not heat. I checked
You should get 120 volts on both sides. Check your heater coil for continuity.
Feb 21, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Plug sparked when moved and now no heat and timer doesn't work what is a pig tail? how do we replace
Since the electric plug sparked when you plugged it in, I would check out the dryer main power cord or pigtail. Use a multimeter or ohm meter to check the dryer cord for continuity. This will show you whether the dryer cord is good or not. No continuity = bad cord. You can also use the meter to check the electrical block where the dryer cord is connected. Try these things first and let me know what you find out. We'll go from there, okay? Hope this helped and best wishes.
Jul 31, 2009 | Kenmore 500 6952 Dryer
Can't make the dryer heat
64c4e1e.jpgyour 2 outer wires which are hot go to the outside and the middle wire is neutral The green wire is a ground wire to frame.
Mar 07, 2009 | Whirlpool LER5636P Electric Dryer
Electric dryer internal short
Make sure that the dryer is disconnected from the wall outlet before doing any repairs on it. Electric dryer work on 240 volts AC and this could hurt or even kill you. loose connection on the terminal block will cause the wires to get hot. and melt the terminal block and wires and the pig tail wires. you will have to replace the terminal block and pig tail wires and make sure you use the correct bolts and make sure you tighen them. let me know if this helps.krazytech
Sep 09, 2007 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
Top Dryers Experts
