Question about HP LaserJet 1020 Printer
Plastic metal shavings inside printer
My HP 1020 starting imprinting a line down the right side of paper and making a crackling noise when it prints. At times, it crumbles the paper. Upon cleaning we found shavings--like a metalic film--inside the printer.
I had a similar problem on an hp-3052. I was getting pieces of plastic that were grey and yellow stuck to my pages and all inside the printer then papaer stared jamming. The problem was the fuser sleve which can be picked up on ebay fairly cheap. The bigger problem is installing the sleve over the fuser. I tried the repair my self and broke the fuser assembly. It's a cheap part but a pro should do the install this is definately not a diy fix.
Posted on Sep 27, 2009
Black line going down side of paper from HP laserjet 1018
Roller Drum Problem in the cartridge.
If you are printing bulky document it may damage the roller drum causing dark line starting for both left and right paper. It will get bigger once it span of time.
Or if you are refilling the toner of the catridge, the waste compartment is full and requires to remove the waste tones inside the cartridge.
Or the worst thing is the the FUSER FILM ROLLER (orange plastic roller inside the printer is torn or burn because of heat or bulky printing.
Dec 08, 2010 | HP Hewlett Packard LaserJet 1018 Printer
Lines in printing
...maybe its time to replace fuser fixing film!?
Nov 10, 2009 | HP LaserJet 1020 Printer
Getting vertical line on the right side of the paper
Sounds like a defective toner cartridge. Try replacing it
Apr 23, 2009 | HP LaserJet 1020 Printer
1 inch ink smudge down right side of paper
try going on ur computer that the printer is contected to and have the printer align itself
Mar 17, 2009 | HP LaserJet 1020 Printer
Carttridge is slamming against side of printer, light is flashing, no printing, no paper jam
I suspect the problem for both of you is either the blockage of the position sensing path (a slot in the carriage) or the plastic band that is imprinted with many vertical stripes and lets the printer know where it is and needs to go is not where it belongs.
Open the printer as you would to change cartridges and look carefully with a flashlight inside for a thin ~ 6mm (~1/4") plastic strip and insure that it is clean and stretched between both ends. One end is normally anchored to the chassis, the other attached to a spring suspension.
Nov 05, 2008 | HP D1560 Deskjet Printer InkJet
Hp laser jet 1020 has refuse to print
try to see if the printer will print anything by opening and closing the top door that leads into the toner seven times just open and close, if the printer prints a paper with lines then the printer is working now if the printer doesnt then try to take out the ink, paper and unplug the power cord and let the printer set for about three minutes..
If the printer does prints now it up to the printer spooler itself make sure thier isnt any jobs stuck in the spooler, if there is delete them and also reset the printer spooler, if that doesnt clear them out reset the computer, this will help it, finally when you have that done, do a test page by going into the printer and faxes and right clicking the laserjet 1020 going into properties, and in the general tap click on the test page this should print out a test page. if it does then your printer is up and running.
Jul 09, 2008 | HP LaserJet 1020 Printer
HP 1020 printing problems
It seems like the problem is not the printer, but your Excel file.
Jul 27, 2007 | HP LaserJet 1020 Printer
Printer making funny noise and print is almost peeling off the page on the right side
Your problem is with the fixing film in the fuser assembly (HP Part #RM1-3044). The brown material you see is the plastic film ripping and peeling off of the hheating element.
Jan 23, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 1020 Printer Logo
135 people viewed this question
Seeker5211
Seeker5211
