Question about Samsung LE32A457 32 in. LCD TV
I cannot get my PC sound to play through my Samsung LE32457A HDTV
Currently using a DVI to HDMI cable for video, which works fine, but my 3.5mm to twin phono (red+white) jack cable doesn't appear to be doing anything. The red/white jacks are right beside the HDMI input on the back of the TV, grouped together in a white outline, so I know those are the intended ones. I have got sound coming out of the 3.5mm jack on the back of the PC when I plug my PC speakers into it. Have replaced the 3.5-to-phono cable once in case of a faulty cable, too. There appears to be no 3.5mm input on the back of the TV, so I cannot use a 3.5-to-3.5 mm cable.
Any suggestions?
http://www.hdtvtest.co.uk/image/hdtv/Samsung-LE40A656/rear-connections.jpg <- back of TV
  • 10,594 Answers
I hope 3.5mm to twin phono would have plugged in headphone jack of PC to get sound for TV, right?
Reduce PC volume level up to zero and increase it very little bit to get sound in TV.
TV is getting excessive sound level from headphone jack and causing mute circuit to activate to avoid any internal damage.
Posted on Sep 26, 2009
Testimonial: "Good advice, but didn't work. :("
  • Shahid Electronics
    Shahid Electronics Sep 27, 2009
    Unplug TV for couple of minutes from AC wall socket, replug back in, turn it On and try above method.
  • 30 Answers
You will have to use a HDMI straight cable. You can not use the RCA jacks when you are using the HDMI. because the HDMI carries the sound
How to connect a Samsung R700 PC to Sony LCD TV KDL-46S2010
hi my name is Rui i would like to help you with your problem...
its just easy to connect a PC to a sony lcd tv...^_^ here are 5 ways to do it...
1. S-Video - This is probably the most common method out there currently because an S-Video Cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA Cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Coverter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
just try hooking up 1 of this tips i give you.well if you ask me i prefer HDMI & VGA. ^_^
but it will still depend on your preference..
hope this will help you... Good luck... ^_^
Jul 17, 2011 | Samsung Computers & Internet
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
I use attached the pc on tv but i didi not here any sound please tell me sound pin cable attached the tv?
Hi sahazada pak,
As i know, TV set not support sound from PC input.
If you want here sound and still working with PC, you should use HDMI or DVI input from your PC out. HDMI has support image and sound in one cable. DVI only image without sound. if you use DVI , sound pc should connected to audio in.
Good luck.
Mar 22, 2011 | Samsung HLP6163W 61" Rear Projection...
I cant connect my acer aspire 5810 tg with my samsung lcd tv.the tv say "NO SIGNAL"
So here's a quick walk-through of all the methods that I know (if you know any more, please comment) to connect a laptop or PC to your TV:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here's a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel free to comment!!! Thanks!
Nov 13, 2010 | Acer Computers & Internet
How could i connect this tv to laptop
Connect by this way:
Sep 16, 2010 | Samsung CW29M64NS 29" TV
How do I connect my dell laptop to my LG LCD TV
1. S-Video – This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI – Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box – This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
May 30, 2010 | Dell Latitude E6500 Laptop
Conecting laptop to tv
1. S-Video ? This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You?ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC?s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work. 2. VGA ? If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won?t find a VGA port on regular TV?s though, so this option is if you have an HDTV. 3. DVI - DVI stands for Digital Visual Interface with ?digital? being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80. 4. HDMI ? Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI. 5. Scan Converter Box ? This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Apr 07, 2010 | Hannspree XV37 HDTV 37 in. LCD TV
Link my acer aspire 592o laptop to my panasonic plasma
1. S-Video – This is probably the most commonmethod out there currently because an S-Video cable is cheap as heckand just about every TV under the sun has a S-Video port. You’ll haveto make sure you laptop is equipped with this port. Remember, there aretwo types of S-Video cables: 4-pin and 7-pin. Mostlaptops and PC’s are equipped with a 7-pin port, so if your TV only hasa 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will bebetter off connecting using a VGA cable. It gives much better qualitythan S-Video and as with S-Video, the cable is very cheap. You usuallywon’t find a VGA port on regular TV’s though, so this option is if youhave an HDTV.
3. DVI - DVI stands for Digital Visual Interfacewith “digital” being the key word there. The digital signal will give ahigher quality picture than either S-Video or VGA. Of course, yourcomputer will need to have a DVI connection and your TV will need to bean HDTV. This cord is definitely not cheap, it ranges anywhere from $40to $80.
4. HDMI – Using HDMI will give you the best qualityby far. No computers that I know of yet have HDMI ports, but you canget a DVI to HDMI cable to connect it to your HDTV. HDMI is compatiblewith DVI.
5. Scan Converter Box – This is the last methodthat I could think of and it involves using a scan converter box, whichtakes a VGA signal and converts it into S-Video or component video.
Jan 26, 2010 | Acer Aspire 5920-6335 Laptop
PC to TV can't seem to get to work.
okay buddy its esay just give me a good rate!
u select:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
Feb 06, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Play station 3 hdmi-dvi
Yes you can. It will not be like a HDMI cable but it will be better than the RCA. Your image will be in your HDTV (1920 × 1080). But you will have to buy a HDMI cable and and HDMI-DVI adaptor. You will not have sound so you will have to connect either your RCA or if you have a Digital Optical Audio sounds better.
If you have any questions just ask.
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Samsung LE32A457 32 in. LCD TV Logo
810 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
