I want print out by runing foxpro programming so what command use in foxpro programming for samsung laser printer
SOURCE: printing dbase reports on a samsung laser printer
dBase as in the old DOS based database program from the late 80s - early 90s? If so we'll need some more details on which version (II, III or IV)and the Operating system the program is running in to start with.
SOURCE: I HAVE A SAMSUNG LASER PRINTER BLACK AND WHITE IT
You need to click "start" then "printers and faxes" and check to see if your printer is installed. If it is, look to see if there is a little black check mark on it. If it isn't, click once on it and then right click and select "set as default printer". If it is indeed trying to print to file, this will solve your problem.
SOURCE: I have Samsung CLP/610 laser printer and need to
"MP tray" refers to the manual paper tray. This is the common setting for most word processors whenever printing media other than paper. This message will come not only for labels, but for transparencies, card stock, envelopes, etc. The reason for this is that the manual paper tray is designed to provide a straighter paper path that helps preventing your labels from peeling inside the unit. Therefore, I do not recommend placing them in the regular paper tray. Take note that you should also check that the labels purchased specify they are meant for laser printer or copier. Regular labels, or labels designed for inkjet printers will surely come off inside your printer and cause damage that the warranty will not cover.
Be blessed.
SOURCE: my samsung 3175fn laser printer keeps getting a black line and ye
The printer has a build up of toner on the drum/fuser, a maintenance cleaning done by certified technician of the printer would fix this problem.
SOURCE: My Samsung laser printer clx3175fn says "toner
remove the power plug and the usb connector connect them after 1 min then right click the printer icon in the task bar clear all the files in them then click start setting then click printer make the printer your default printer right click the default printer click properties then click print a test page some time you will need to restart you computer
