Question about Evoluent Vertical Mouse - Right Hand
Evoluent VerticalMouse 3 Rev 2. Scroll wheel issues.
Model: Evoluent VerticalMouse 3 Rev 2. Scroll wheel scrolls very erratically. Sometimes the document (be it word, pdf or other) does not move in response to wheel movement; mostly it does, but when it does, the action is not smooth, and unpredictably fast or slow.
I have already sent one VerticalMouse back to Amazon for this reason, but I have the same problem with the replacement. I have tried reloading drivers etc., and playing with the wheel settings (including the accelerated scrolling function), but the problem persists.
My scroll wheel skips, jumps, scrolls backward or on its own. Can I fix it?
Take the roller ball out of the bottom of your mouse if it's the older style and clean the dirt and dust of the roller wheels with a q tip and alcohol. If it is an optical mouse try putting a piece of white paper under it when you use it this may help. If not it is time for a new one.
Mar 14, 2016 | Computers & Internet
Evoluent mouse keeps disconnecting.
You might try looking at this photo stream: https://secure.flickr.com/photos/austinhappel/10940723443/
Iwonder if the main cable/wire, which takes a 90 degree turn inside, under the circuit board, could be the problem. I pulled my wire/cable out from under there (after removing the board's screws), and un-crimped it. Currently trying it that way. Haven't tried the method in the photostream above.
Oct 15, 2012 | Evoluent VerticalMouse 4 Wired Left-Hand...
Scroll wheel not functioning at all
Initially, go and buy some elctronic switch cleaning spray and spray all around the mouse especially the wheel and this may clear all the dust and skin particles that block mouse and leyboards during PC usage. If this does not work, re install it and see if that is any better.
Feb 17, 2010 | Manhattan Mouse
Remove cover
There are four screws on the bottom of my VerticalMouse 3 Rev. 2. Two are immediately visible. A third screw is hidden under the nylon "foot" near the USB cable; use a small flat screwdriver (e.g. for eyeglasses) to remove the foot without damaging it. A fourth screw lies hidden near the bottom of the big label containing the model number, etc.; you must push the screwdriver through the label.
Dec 19, 2009 | Evoluent Vertical 3 Mouse
The scroll wheel on my Dell 2-button mouse doesn't scroll
my best suggestion is that at the cost of a new mouse replace it. No there is no way to service the scroll wheel in a mouse
Mar 25, 2009 | Dell Dimension 4600 PC Desktop
Wheel won't scroll
Hello, Please do service of your mouse, may be due to some dust over the scroll thanks
Sep 08, 2008 | GE Wireless Optical Mouse
My wireless Logitech mouse is erratic. Currently, the green light at the bottom and the red light on top are bright lights. I'm assuming that the batteries need changing. I cannot find where the...
At the rear of the mouse you will find a button , push the button and pull the top thing it will come out (it is in a straight line from scroll wheel ) and then you can change the battery
Apr 22, 2008 | Computers & Internet
Driver
you don't need a driver. to switch pc, use keystrokes below.
' Scroll Lock / Scroll Lock / 1 or 2'
'1 or 2' being the pc location on the switch.
hope this helps.
Mar 04, 2008 | KTC IntelliView KC102P (DSKTCKC102PS2)...
Evoluent Vertical Mouse - Right Hand Logo
645 people viewed this question
Top Evoluent Computers & Internet Experts
Mike
Mike
Bill Boyd
Are you an Evoluent Computer and Internet Expert? Answer questions, earn points and help others
