Question about Maytag MDE4806 Electric Dryer
My Amana electric dryer will not blow hot air.
  • Maytag Master
  • 7,482 Answers
Your problem could be faulty heater element and or faulty thermostats.
This is a normal problem if the blower is blowing cold air.
Posted on Sep 26, 2009
The dryer is not getting hot its only blowing cool air
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 28, 2011 | Amana NED7200TW Electric Dryer
How hot should a gas or electric dryer get, mine seems too hot
if the dryer is running hot it's because you haven't cleaned out the dryer?try running it with the vent line disconnected from the back of dryer,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to blow out the line,make sure the outside vent is clear first,no screens or cages in the way,if there is remove them all they do is catch lint,next unplug the dryer,clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is,if you have a shop vac that blows on one end blow off the motor and blow all the lint from the back of dryer to the front so you don't have to remove the drum,do this once a year and you shouldn't have to many problems with the dryer
Mar 20, 2010 | Amana DLE330RAW Electric Dryer
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Dle330raw not heating.replaced heating element was working on time dry then stopped, replaced thermostate. no heat at all now.
Check your blower, it may not be blowing hot air to your drum..You did not say if it was blowing or not.
Sep 26, 2009 | Amana DLE330RAW Electric Dryer
Dryer runs hot and a little louder
sounds like the thermostat needs to be replaced
Jun 15, 2009 | Amana ALE643RB Electric Dryer
Dryer won,t get hot
It's not a circuit breaker your chasing. Check your vent to see if it's clean. You could have a bad element.
Apr 12, 2009 | Amana NDE2330AY Electric Dryer
Dryer doenst stay hot
It is possible that it is the high limit, make sure that the vent is free of debris ie lint. Also confirm that the blower fan is turning that blows the air out of the vent. if thd vent is clogged it will cause the high limit to open and also the high limit will open if the vent blower is not turning.
Mar 07, 2009 | Amana NDE2335AY Electric Dryer
Amana dryer
If you have voltage across the heating element and it does not heat, replace the element. If you have no voltage, trace it back to the thermostat and control board.
Oct 02, 2017 | Dryers
Dryer runs way too hot. can't touch clothes
go outside and check the vent outlet. is air blowing out. if not clean vent, make sure vent hose is not kinked.
Dec 20, 2008 | Amana ALG331RAW Gas Dryer
KENMORE DRYER
Electric or gas?
Sep 13, 2007 | Dryers
Maytag MDE4806 Electric Dryer Logo
120 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
