Question about LG KC910 Renoir Cell Phone
Hi my lg renoiur screen stays on laoding when i try to use the camera both from the side button and threw the menu. help any ideas.thanks xx
Mine too an no help any where, ive thought of trying to put new firm ware on but how do you get tht
Posted on Jan 13, 2010
How to reset code error c6100
Please Follow step by step..
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
Read more help..error code 0xc18a0106 on c5180 Photosmart and HP Printer Support
Thanks,
Sep 10, 2014 | Office Equipment & Supplies
False empty toner reading
The problem can be may this however hard resetting it can fix the issue
8. Restart printer.
Jul 12, 2008 | OKI C5500n Printer
Hi, I have an LG RZ-20A70 TV and when i watch TV or play xbox the side are cut off the screen. (think its the picture ratio) any idea how to change this? as i have tried everything!
yes it is a picture ratio issue .
You need to look for the main menu tv setup button, its green on my lg remote .
Once you select this you should have an option to change screen ratio to 16.2 or wide screen if your tv supports wide screen .
Look for a little tv icon on screen and select that ,this should get you to pic set .
Jun 16, 2011 | LG RZ-20LA70 20 in. LCD Television
After replacing the magenta and cyan drum units the machine power off and shuts down while idle
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Please perform these troubleshooting steps as mentioned:
Turn machine on while pushing and holding the (+/-) menu buttons at same time.
5. Press (- or +) button until (“ENGINE = PARAMETER SET 2”) is displayed.
6. Push Enter button
7. "TONER SENSOR = ENABLE" is displayed.
8. Push Enter button
9. Press (- or +) "TONER SENSOR = DESABLE" is displayed.
10. press "ON-LINE/CANCEL" buttons at same time.
11. (*) is displayed.
12..... READY
Thanks for contacting Fixya and please accept the solution if it has helped you.
Mar 22, 2010 | HP Officejet 5610 All-In-One InkJet...
Inspiron e1505 screen in darker on the right side
Hi
Thank you fr your query
From what you are describing it sounds like the LCD screen is starting to burn out
Please try the following
1) Switch on laptop
2) Continuously press the F8 key until a start up menu is presented
3) Chsoos safe mode from the options
4) Once safe mode has laoded up check the screen to see if it is still dark
I believe it will be.
If it is you will need to book the laptop into a reputable PC shop to replace LCD screen
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | Dell Inspiron E1505 Notebook
Unlock code for LG KP500, free and it would be good if it was'nt BS. I've tried 2945#*# and 2945#*7101# etc. none of them worked, it just said ''please try again'' thx in advance
some cod
Lg old and New
LG Chocolate =2945#*#
lg kf700 =3845#*700#
lg ku250 =26911147#*250#
LG 900 v09e
Citazione:
TEST MENU: 277634#*#
LG 900 v10b
Citazione:
TEST MENU: 082065#*#
LG U970 Shine
Citazione:
TEST MENU: 26911147#*970#
LG L600V
Citazione:
TEST MENU: 63342425#*#
LG KU310
Citazione:
ENGINEER MODE: *72346#96
LG KU800
Citazione:
TEST MENU: 26911147#*#
LG KU830
Citazione:
LG KU950
Citazione:
TEST MENU: 7973845#*#
ENGINEER MODE: 21738#96
LG KU990
Citazione:
TEST MENU: 3845#*990#
ENGINEER MODE: 364663#96
MENU NCK: 2945#*990#
KF310 kF311 reset codes
Test menu: 3845#*310#
for kf311 3845#*311#
engineer mode: 364663#31
menu : 2945#*#
This procedure is for LG CT810.
To RESET your phone back to factory defaults which will erase all current content and revert the device back to original shipped configuration:
1. Turn off your phone,
2. Remove the back panel and take out the battery for about 30 seconds,
3. Put the battery back into the device and replace back panel,
4. YOU MUST PRESS AND HOLD THE FOLLOWING BUTTONS SIMULTANEOUSLY!
a. Left Volume Down Button, AND
b.Right Camera Button, AND Power Button
5.Hold them until you see the green Windows Mobile startup screen and then you can let go,
6. After a few moments, you should see the initial screen caliberation screen,
7.Your device is now RESET/RESTORED to Factory Default (this assumes you have not applied a custom ROM, in which case the reset will simply go back to the defaults of that package)
LG XENON Reset.....Security Solved!!!!
Lg security solved!!!!
Hi there, follow the steps below for LG XENON
remove sim card and tap emergency or From the standby screen
- Select Dialing Button
- Dial "3845#*500#" (you will then be in the engineering menu)
then reset phone
voila password gone
done it already
Pics Here
LG KE850 ***** security
without and with simcard: 1475369586#*# try this one too: 338464#*# ,then go Reset or restore default.
LG KU800 reset code = 277634#*#
kf311/310 =no sim inside
3845#*310#
KT520 user code reset =338464#*#
Sep 30, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
LCD screen black when photo being taken
Hi!
Have you tried pushing the button first under the mode dial? It changes view mode, just above the MENU button?
Tom
Aug 01, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
My camera doesnt work on my cu915 lg vu
have you ever taken pictures with it because that happens sometimes with me and it just means that my memory is taken up by having so many pictures
Nov 26, 2008 | LG Vu CU920 Cellular Phone
Trouble entering camera mode
try resetting the phone back to it's default factory settings, that should help.
Jan 11, 2008 | Sony Ericsson Walkman W810i Cellular Phone
LG KC910 Renoir Cell Phone Logo
116 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
