Question about Amana Dryers
My dryer is just throwing cool air - Amana Dryers
  • Amana Master
  • 7,482 Answers
Could be your problem is a faulty heating element or thermostats.
Posted on Sep 26, 2009
Amcor ac
Video around the whole unit. Is unit the type to exhaust hot air from Condensor coil to the outside.?
Jul 07, 2013 | Heating & Cooling
Yapmagic split unit aircon
if the indoor unit is throwing air but no cooling then check if outdoor is throwing hot air or not. May be the refrigerant has leaked. call a technician.
Jun 20, 2013 | Heating & Cooling
Turns on however does not throw air
If you mean the indoor blower motor wont run, check the fan relay, board or stat, the motor if getting voltage and not working is bad if no amp draw, if you have an amp draw try a capacitor for the fan
Apr 22, 2012 | Ruud UBHC Air Conditioner
2004 camry ac light blinking and throws hot air. Suggestions?
My 2003 Toyota Camry AC often starts blowing hot air and the AC light starts blinking. I don't know why the following process works, but it does. Using the temp selector (left) reduce the temperature all the way down to Max Cold and then push the Auto button. It will start blowing out very cold air. After a little while push the temp selector to the desired temperature.
Apr 03, 2012 | Cars & Trucks
Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Jan 08, 2009 | Frigidaire Dryers
Whirlpool Dryer won't start
You probably had been using the dryer alot today. As long as the motor was running there was enough air flow over the motor to keep it just cool enough to allow it to continue to run. When you stopped the dryer the heat tripped the thermal protector in the motor. Let it sit an hour or so and it should restart. The motor is probably coated in dryer lint, and / or the motor bearings are getting bad. If you space your drying loads out a bit you can get by for a long time without having to do anything.
Sep 16, 2008 | Dryers
Dryers Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
