Question about Maytag Legacy Series Top Load Washer
My machine is not aggetating it just keeps filling with water
  • 1,531 Answers
If the water is not over flowing on the floor.make sure your washer is off,then pull the drain hose up to the level of the back control panel you should here water flowing out once this stops.keep the hose up for aminute and restart your waher and it should fill up to the proper level and shut off and start washing
Posted on Sep 26, 2009
Washer will not fill with water.When you start washer will not fill with water but aggetates.Water is turned on.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 11, 2013 | Washing Machines
Ge washer will not aggatate
Does it fill and not agitate? If so, you will need to replace the lid switch.
Aug 23, 2012 | GE WBSR3140DW Top Load Washer
I have an older (about 1998) Whirlpool washer. After the aggetation cycle the machine fails to drain. We can back up the cycle to aggetate and begins aggetate again. It again fails when it gets to the...
You quite possibly have a small article of clothing such as a sock, that may have been washed over the top of the inner tub and is in the outer tub and blocking the drain hose to the pump.
If you can remove the front cover, you can check to see if the pump is clear and also the belts underneath.
If it appears to have something in the pump you can pull the hose (be prepared for alot of water) and pull it out of the pump.
If it is in the outer tub, you can fish out the blockage with a straighten coat hanger wire with a small hook bent on one end.
Let me know if you have success...
k
Jul 09, 2009 | Washing Machines
MY WVSR1060AOWW washer does not aggetate or spin but drains water
the common problem for this is you need to replace the cappacitor in the headset this is usually a four inch long white cylinder with two to four wires coming out of it
Jun 11, 2009 | GE WVSR1060A Top Load Washer
Amana washer LWA50AW
I had the same issue last year on y lwa50aw. It is the timer. Get the speedqueen version it is about $50 -$80 and aboyt 15 minutes to replace.
Apr 19, 2009 | Amana LWA40A
Washer fills with water, spins but does not aggetate
LG washing machine, the water continue, not stop
Mar 15, 2009 | Washing Machines
Washing Machines Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
