Question about Canon Pixma MP500 All-In-One InkJet Printer
I get a black streak on the back of the paper. I have tried cleaning which did not help.
  • 4 Answers
SOURCE: Large black streak down the back of the paper
This is a fairly common problem. More common when you use junk cartridges from printcountry.com.
1) you will need some cotton swabs, isopropyl alcohol and "canned air" or any pressurized computer cleaner.
2) lift up the top console while the unit is on and wait for the cartridges to reset to the center position.
3)Release the grey lock on the LH side of the cartridges and remove cartridges.
4) take alcohol soaked swabs and clean bottom of ports and nozzles.
5) blow out with air.
6) go into program and run clean and align programs. (if you don't have them go to google and type canon mp830 support)
7) retest.
8) if this doesn't work, give to someone you hate or throw out window.
Posted on Aug 20, 2008
  • 59 Answers
SOURCE: Scanner/Printer imageCLASS MF6550
Does it do it on prints aswell as copies?
If so open up the Left hand side door if you peer inside at the fuser (hot bit) can you see any damage. if so needs replacement.
Also could be the drum, look in the same area at the green/blue cylinder, these do up to approx 30,000 pages.
Hope this helps.
Posted on Mar 26, 2009
komguy
  • 2306 Answers
SOURCE: MP 830 copier; just put in new PGBK cartridge; now
ink is coming up from below where it shouldn't and coating the exit rollers. It will need a good cleaning and a mylar shield to prevent ink coming up in the future. An $80.00 repair in our shop.
Posted on Jun 19, 2009
SOURCE: Big black vertical line on back of the paper.PIXMA CanoniP4200
Your black ink seems to have spilled a bit at the nozzle. The fact is even if you do nothing it should seize staining the back of the paper after a while, so long as the spill is only temporal. But if you want it over with quickly, you may try printing quite good number of pages till you see that the stops. With every print you will most certainly observe that the stain will reduce. Otherwise if you can reach into the printer with a stick or something, you may try to clean it.
Posted on Dec 19, 2009
  • 5188 Answers
SOURCE: MP 610 is leaving black ink streaks the length of
That sounds like the ink is coming off the waste ink absorbers. Try blotting the excess ink off the bottom of the printer with paper towels. The ink absorbers are small pads at the bottom of the paper feed path. With work, you can pull them pads and rinse them clean and then reinstall them when dry. Unfortunately, this can take almost disassembling the printer. Simply absorbing some of the excess is a temporary step.
I hope this helps.
(there is a counter that indicates when (based on average use) the waste ink absorber is full. The printer will stop working when that number is reached. Unfortunately, I haven't seen a reset for this model that actually works.)
Posted on May 17, 2010
Dark streak on paper
you need to clean the rollers. consult the manual about cleaning the copier. if you don't have a manual, then get some methyl alcohol (any alcohol that evaporates completely will do). use a lint free cloth to rub a small amount of alcohol on all roller surfaces (accessible via pull-down compartments on front and back, usually).
Nov 29, 2011 | Canon PC-921 Black and White Copier
We have a Brother intellifax 4750e. When we send a fax, there is a black streak down the right hand side of the paper. When we receive a fax, the streak is not there. The streak is about 1" wide. ...
Try cleaning the rollers with rubbing alcohol using a good quality paper towels, I find there is a buildup on the rollers causing streaking on the paper. If that fails the print head must be suspect.
Dec 30, 2010 | Brother Office Equipment & Supplies
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
Streaking problem on Sharp Copier SF-7321
Clean the optical mirrors on the scanning side and also remove the drum and clean a mirror beneath. Check also the drum condition and replace if necessary.
Dec 21, 2009 | Sharp AR-5320 Black and White Copier
Brother mfc. I made the mistake to use canned air to clean copier which got into my drum and made black streaks on my paper I keep cleaning the black streaks off the drum but when i put it back in i have...
First clean the glass of the laser.If you open the front door remove the drum from the machine just above were the drum was in place there is a glass mounted.Try and make a test print.If the streaks is still printing and you can see the streaks is deffinately from the drum you can strip the drum,clean the corrona wire and grit,and clean the drum brush.Strip only the drum unit if you sure the lines is caused by the drum.
Dec 11, 2009 | Office Equipment & Supplies
BIG BLACK STREAK ON PAPER
If you're experiencing horizontal streaks, and already tried changing cartridges but that don't help, look in the bottom of the paper tray. If that small metal ground terminal gets ditry or bent, that could be the cause.
May 08, 2009 | Brother HL-2070N Laser Printer
Brother MFC 4350: Black Streaks on Page
Check your office supply store for printer cleaning paper. It is a heavier weight paper that is sticky on both sides. Run it through several tines to get paper dust off the rollers and paper path.
Aug 09, 2017 | Brother MFC 4350 All-In-One Laser Printer
Wide black streak on back of printed paper
it is not directly coming from the head. Probably you are printing your photos without borders. This means that the printer prints slightly beyond he paper. As a consequence is sprays ink on the mechanics and after a while it starts to smear on the back of the paper.
This phenomenon is even mentioned in the printer manual (kind of caution when selecting borderless printing).
There is a menu item in the printer utilities that lets you clean the printer mechanics with a folded paper. I tried this, but it helps only little.
I have the same effect on a pixma IP 4500 , and I live with it.
Cheers
Critter
Dec 29, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Inkworks
866-381-0541
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
Black smudges on printed page
Are you sure this is a Designjet 450 (large format printer) and not a Deskjet 450 (portable printer)? The following assumes you have wispy black streaking on the printed side of the paper. If the streaking is on the back side then post more details of the printer model and the issue.
In either case the most likely cause is a buildup of fibers on the underside of the printheads or carriage, causing wisps of black ink to be dragged on the paper when the carriage reverses direction. You can clean the printer as shown at the following (though the details will be somewhat different for the Designjet or Deskjet....).
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 16, 2008 | HP DesignJet 450c InkJet Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
old marine
old marine
