Question about Konica Minolta magicolor 2500 Printer
The inside of my magicolor 2550 printer was filling up with toner so I vacuum it outside during the day. after putting it back together and testing it I found the print quality really bad, light and missing part of the page. Do I need to replace the drum unit because it was exposed to light?? if so where can I get one.
  • 214 Answers
SOURCE: where are the toner cartridges in magicolor 2300 dl
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Posted on Sep 02, 2008
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
Posted on Jun 01, 2009
n25an
  • 622 Answers
SOURCE: Magicolor 2300DL Printer. Blank pages come out. No
here is my thinking... toner... goes from toner container... via developer to drum... where it gets info and then to paper where it gets placed... and then to fuser where it gets cemented...
if pages are coming out blank... check if toner is full... then check if developer unit is turning... then check if there is an image on the drum... if no image on drum then the charge roller or charge wire is not working....
if you still think all is ok up to this point then check your fuser... if it is cold after your machine is on for five minutes then its blown...
thats how I would check it...
Posted on Mar 14, 2010
SOURCE: I have an error message
The K toner is the black toner. The K stands for "Key" as in primary toner.
Pages 80-107 list the toner part number that you will need to order as well as how to remove the old and install the new toner.
Posted on Mar 15, 2011
I have a Konica Minotla 2550 Magicolor. I had some paper tear inside last week. I pulled it all out and since then the ink is not "baking" on the paper. It is smudging right off and smearing while i
The cartridges and mirror have nothing to with that your fusing unit is bad. It the think that gets hot inside the machine. The machine use Heat and pressure to fuse the toner to the paper, that is not happing. SO replace the fuser
Feb 12, 2015 | Konica Minolta magicolor 2550 Laser...
Magicolor 2550
Your toner might have become hard because you have not used it for a while.. or your copier mainboard has malfunctioned..
Dec 19, 2013 | Office Equipment & Supplies
Bizhub 421 driver
IF YOUR USING A BIZHUB 421 DRIVER FOR A MAGICOLOR 2550, THAT ITS YOUR PROBLEM YOU NEED TO GO TO
onyxweb.mykonicaminolta.com/OneStopProductSupport?appMode=Public
SELLECT MAGICOLOLOR PRINTERS 2550
WHEN EVER I TRY TO PUT THE FULL LINK, IT WONT LET ME POST, BUT I YOU PROBABLY KNOW WHAT TO PUT ON THE FRONT OF THE LINK
Aug 21, 2013 | Konica Minolta magicolor 2550 DN Laser...
I have an error message on my magicolor 2550 ( Konica minolta) that says Replace K toner??
Mar 15, 2011 | Konica Minolta magicolor 2550 Laser...
Help with emptying waste on a 2300Dl laser printer
You just open the front door, pull the bottle off, and empty it. Be aware, though, that this is one of the messiest procedures that you will ever do. The toner is so fine and dusty that it spreads everywhere when you dump it and it is vey hard to clean up. I put on plastic gloves, took it outside, put a large ziplock bag inside a tall garbage bag, and sealed this around my wrist as well as I could before dumping the toner. I still had a real mess. If I had not had a couple of the "magnetic" toner clean-up cloths sent with recharge kits, I would have been hard-put to clean up the bottle well enough to use it. And, it still took me a couple of days to clean my hands. A new bottle simplifies this. You just take off the old one, put in a plug, and discard it. Costs $30-40 but may be worth it.
Jan 11, 2009 | Konica Minolta magicolor 2300DL Laser...
RED over pictures
You need to remove all the toners and drum and vacuum the entire printer out. you need to clean the fuser very thoughly. You should take it out as well and clean it.
Sep 03, 2007 | Konica Minolta magicolor 2300DL Laser...
Magicolor 2300dl
Clean the fuser, opc drum, and the basic inside of the printer with a vacumm. Suck don't blow with the vacuum.
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor  2500 Printer Logo
23 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
