Question about Cobra 29 LTD CB Radio
Transmitting and receiving
I believed i did the swr calibration correctly .i have attempted to use the cb radio,all wires,mic,antenna, are put in place correctly, and yet i still cannot received or transmitt, meaning that when i try to adjust the squelch i hear nothing even after adjusting. I even drove next to the highway to make these adjustment,as the truckers come by and yet nothing,pa sytem works from existing hookup from other cb radio i had.By the way i have brand new cobra 29 ltd classic that i just purchase.i have try 2 different antennas,both are good ones.
    Guru:
  • 773 Answers
RF gain should be all the way up. Turn the squelch all the way down. Turn the ANL/NB to just ANL.
Turn the dynamic up at least 3/4.
Once you have confirm you can receive and transmit, then you can turn up the squelch up until white noise just stops.
Make sure you are on 19 by the highway. Key up and say break break one nine, can some one give me a radio check please.
you should get a response.
Your RF gain is how much you receive. the higher it is the more you receive. In normal operation there is no need for it ever to be less the all the way on.
Squelch is just to knock out fuzz, and if you only want to hear people close not far. A little less then half way is a basic setting.
the ANL switch is the automatic noise limiter. if you have interference from your vehicle, like engine noise, turning this on will quiet that. If it is extreme engine noise then switch it to NB, noise blanker. It is just a more intense setting.
your dynamic is how loud your audio is. if its low or all the way down, you will not transmit audio loud enough for people to hear. If its a stock radio and has not been tuned, if you turn it all the way up, that is fine.
Posted on Oct 01, 2009
    Problem Solver:
  • 12 Answers
When you key the mic, does the TX (transmit light) come on and does the TX meter swing to the right? When in RX (receive mode) does the needle bounce even though you can't hear anything?
If the meter DOES swing and you get the TX light, plug in an external speaker to the back (there's a spot marked for this, be sure to plug it into the EXT SPKR and not the PA hole) if you can hear now, the problem could be a faulty speaker wire or the internal speaker has become unplugged. A soldering iron can fix it if it's a broken solder joint, you'll have to remove the speaker cover (the bottom radio cover) to see. If it's unplugged or not plugged in tightly, you'll see this too. Gently push down on the speaker plug and see if this does the trick. If the speaker is blown, you already have the radio open, unscrew the speaker from the cover and unplug it from the circuit board and install a replacement speaker. It's quicker and a lot easier to just go buy an external speaker to begin with though.
If the meter doesn't move at all, when you key up the mic, try another mic. You can usually purchase a replacement mic inexpensively, and it's always good to have a spare mic on hand anyway. It is possible to have a brand new setup out of the box with a faulty mic, it doesn't take much to break a solder joint inside the head of the mic.
Posted on Oct 25, 2009
CB warning antenna on a cobra 29 lx camo
You may have blown out the output transistor in the CB. Can you still calibrate the swr meter? The K 30 isn't really a very good antenna. The Lil Will isn't either. I'd try a K-40 or a better model Wilson antenna.
May 08, 2016 | Cobra Radio Communications
I just mounted a dual antenna set to the bed of my pick up.. i took a grinder to the underside of my bed to get a good ground to the metal...my cb turns on and i calibrated it just like i always do... i...
You need somebody with a swr meter to calibrate the installion, if your antenna light is coming on the swr readings are to high and you risk blowing the rf transistor in the radio.
May 08, 2012 | Cobra 29 LTD CB Radio
Galaxy DX 98VHP meter stopped moving . There is no swr reading, nothing. Even with a seperatye meter atached or a dummy load, the meter on the galxy is not working. Did I lose all power?
You appear to be aware of you antenna system with the separate meter attached so the tells me you dont punish a radio with an high swr. I am just guessing red wire/solder in mic cord at plug given that it is a side mic mic jack.
Stock mic
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Jul 02, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
I just need to know how to use it for conversations and what every turn dial means.
you need to hook this up to an antenna. If you are putting it in a car, you need a mobile antenna, if in a house, you need a base antenna. The antenna needs to be tuned for best SWR or you will damage the radio.
Starting from the left of the radio.
Knob 1. Volume/ squelch. The little knob does the volume of what you hear. Big knob squelches out static noise.
knob 2. Dynamike. This is the volume of your voice transmitted. Its how loud people hear you.
Knob 3. RF gain. This is the receive sensitivity. The higher you turn this, the further you can hear. There is almost no reason for you to have this anywhere but full.
knob 4. Delta Tune. This knob should be in the center. If you encounter some one transmitting off frequency, you can move your receive up and down frequency so you can tune that person in. It does not effect your transmit frequency.
Knob 5. CAL. This is to calibrate the meter for taking an SWR reading off the antenna.
Switches starting form the left.
Switch 1. Meter switch. S/RF - will show on the meter, Your signal going out when transmitting, and the signal coming in while receiving. SWR - will show on the meter, your SWR on that channel after you have calibrated the meter. CAL - This is used to calibrate the meter in conjunction with the CAL knob.
Switch 2. ANL - Automatic noise limiter. - This gets rid of electrical interference noise from the vehicle, or other interference sources. ANL/NB - This is the same as ANL, but with NB "noise blanker" This function blanks louder noises that may make it hard to hear people. It's kind of like an automatic squelch, but not nearly as effective as the actual squelch. Also, NB will lessen your receive in that, really low signals will be blanked out.
Switch 3. CB - the radio is in CB mode. This is the normal operation mode of the radio. You can transmit and receive as normal. PA "Public Address" - If you hook a PA speaker to the PA jack in the back, you can mount the speaker on the out side of the vehicle, and talk over it (Its loud). Also, anything you receive over the radio when not holding the mic key, will come over the PA speaker. This is useful when you are not in the vehicle, and need to hear when some one comes on the radio.
Switch 4. BRT and DIM - this is the brightness of the meter light and channel display. BRT stands for bright.
Switch 5. Normal and CH 9, When the switch is in the normal position, everything is normal, but when you flip it up to CH 9 it instantly puts you one channel 9 with out having to turn the dial. CH 9 is the international emergency channel. So it lets you go to Channel 9 quick. when you put it back to normal it will put you on the channel you were on.
Meter explanation. - You have 3 horizontal lines on the meter. the top line is your SWR (only when in SWR mode on the switch. The next one down is you Signal going out. And the bottom one is your signal coming in, in DB's. ***Also noted that part of the SWR line has a CAL )calibration mark. When you have the switch in CAL, and key the mic, you turn the CAL knob up until the needle is at CAL triangle, and then put the radio on SWR and key it. where the needle falls, on the top line is your SWR. If it is in the red your antenna is not tuned, and you can damage your radio.
HERE IS HOW TO TUNE YOUR ANTENN:
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Nov 12, 2010 | Cobra 29 LTD CB Radio
WHEN I PLUG IN VERY LITTLE RECEPTION WEATHER BAND COMES IN FINE. SIGNAL DOES NOT MOVE EVEN WHEN KEY MIKE, CAN'T SET SWR VERY DIM EVEN WHEN ADJUST DISPLAY
1st. You cannot "set" the swr. The swr is not set on the radio. The antenna must tuned to attain an appropriate SWR reading.
2nd, If this doesn't solve your problem then you could have a worse problem. If there is a problem with the mic such as a break in one of the wires, the radio's receive will be off until you put a good mic on it. Try a different mic, and see if the receive comes back. Then check and see if your transmitting better.
As well, your meter could just be bad, as well your coax or antenna. Your receive could be poor if the antenna is not tuned to lowest SWR.
If it has been working up till recently, and you have "set" the SWR on the radio, which is not what the SWR function is for, because you don't set SWR on the radio, you could have been using the radio with the SWR super high and blown the final or other sections of the radio out.
SWR is basically signal reflection. If the antenna is not the right length, it will reflect energy back into the radio and damage it over time. The more an antenna is off from the correct length, the more reflect you will get.
The meter in the radio is used to determine how much reflect you are getting. You ideally want to have the lowest SWR possible.
To check the SWR, you set the meter switch to CAL. Key the mic. while holding the mic key down, turn the CAL knob up until the needle is at the little triangle at the top right of the meter marked by "CAL", Then while still holding the key, flip the meter switch to SWR. where ever the needle is at that point is your SWR.
You want ch 20 to have the lowest SWR. If the swr reading on channel 40 is higher then channel 1 then your antenna is too long. if it is higher on 1 then 40, its too short. Make small adjustments until 1 has almost the same reading as 40. then check ch 20 and it should be real low.
As I have said, if you haven't tuned your antenna as I have just explained, and have been using it as is, the possibility is high that you have already hurt the radio.
Although it could also have a bad meter. Use an external meter to read the SWR.
Other things to check. Make sure cable connections are tight. Make sure coax is not damaged. try another antenna.
Aug 24, 2010 | Cobra 29 LTD CB Radio
29 LTD CB Radio: Calibrate cb radio...
The CAL is to calibrate meter for reading SWR (standing wave ratio) which is reflected power when transmitting back to receiver(radio) from antenna system.
This CAL switch position when selected and mic keyed uses the CAL knob to align the meter needle with inverted red triangle next to cal on meter. Then when you select SWR switch position meter will display accurately when mic is keyed for that channel. Now notice the difference when you go between channels 1 and 40. The ant led light will act as idiot light if it is not lit then you are most likely safe to transmit.
I say system because your vehicle, antenna and coaxial cable are all part of this system. When you have a high reading and have to trim you antenna this is really calibrating the antenna to the vehicles body which acts as a ground plane.
May 16, 2010 | Cobra 29 LTD CB Radio
Can"t transmit
I believe that if the radio is not tuned to the antennae it can take out the transmit crystals and the radio will be inoperative. You will have to take it to a shop that works on CB Radios to have it checked.
Jul 31, 2009 | Connex CX-4300HP CB Radio
The marine cb radio turns on but you can't here noboby talking nor can u talk out from the cb
Sound like either an antenna problem, or a mic problem.
The mic on most cb's also serve as transmit/receive switching. A broken wire or bad switch in the mic or cord can cause either or both to fail.
If you have a bad antenna (or cable), you should still hear squelch noise on receive (maybe lower in volume) and be able key the mic and get a transmit light on the unit. Visually inspect the connector, cable and antenna. If need be use an swr meter to prove the antenna system is bad.
Hope that helped...
Geno
Aug 01, 2008 | Audio Players & Recorders
John Q president cb
If by calibration, you are referring to the check if your antenna is tuned, below information may be of help.
S/RF/SWR/CAL SWITCH. When in the S/RF position, the meter swings
proportionally to the strength of the received signal. When transmitting,
the meter indicates relative RF output power.
When in the "CAL" position, the SWR meter can be calibrated by adjusting
the "SWR CAL" control to the "CAL" mark on the meter face.
When in the "SWR" position, the standing wave ratio is measured.
SWR METER. Measures standing wave ratio of the antenna system.
Used to properly adjust the length of the antenna and to monitor the
quality of the coaxial cable and all RF electrical connections. If there is any
degradation whatsoever in any of the foregoing, due to humidity, salt
spray, vibration or corrosion, the SWR meter reading will rise, thereby
indicating that a problem exists.
To calibrate, switch to the "CAL" position, transmit by pressing the mike
switch, and adjust the SWR control to the "CAL" mark on the meter; then
switch to "SWR" position for the SWR measurement.
If however you are referring to the internal calibration or tuning of the transmit and receive sections, you would need several instruments/equipment such as RF generator (0-30Mhz with 1Khx modulation), Spectrum Analyzer, Modulation Scope, Dummy Loaded Wattmeter, Frequency Meter and some others. These of course are not readily available to the average user.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 12, 2008 | Cobra 29 LTD CB Radio
Uniden pc 78 elite cb
Hi, This is a link to your old post re SWR 3....http://www.fixya.com/support/t180697-pc78_elite_cb As stated SWR 3 is too high, it should be 1.5 or lower. Fiberglass antenna are kinda notorious in setup and experience wise have not performed well or at all. Maybe you should try a different antenna (metal rod). Some good brands/models I have tried with very good results are K40, Hokushin, Comet, Oscar, Maldol, Daiwa. To check if you can receive, stick an ordinay length of wire ('bout 9' long) at the center of your radio's connector. RX should work (pls don't key the mic or TX).
Aug 12, 2007 | Uniden PC78ELITE 40-Channels Base CB Radio
Cobra 29 LTD CB Radio Logo
354 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
