Question about Pit SSR 110CC Pro Beginner Bike
Ran fine on monday but would not start on saturday has gas, clean filter,white hot spark
  • 27 Answers
Bit ov muc in the carb?
Posted on Sep 30, 2009
What should I check to repair this problem? Vehicle has spark and gass flow, but will not fire.
that leaves compression
or coil....can be ok when cold fails when hot
rings worn or valve clearance to check
Oct 12, 2016 | ATVs
Craftsman tractor lt2000 with 17hp Kohler won't start. Ran fine last week. Rebuilt carb, changed oil, and new plug & fuel filter month ago. Has spark and fuel. Cranks but won't fire.
Hi Mike:
It's trying to make you crazy.
I have a model YT4000 and it is a PITA to start when cold.
I pull the air filter, toss in a bit of gas to prime it, and it starts instantly.
I'd suggest that you give yours another try. 3 or 4 times of a couple of seconds each. If it doesn't go, pull a spark plug and see if it is wet or dry. Wet indicates getting gas but no spark. Dry indicates not getting gas.
While you have the plug out, check the spark... Hot & blue.
Hope this gives you some more to work with.
Jun 22, 2015 | Craftsman Garden
Starts but wont run and shuts down in seconds
Read entire posting before doing anything else first.
I discovered what the problem was, after changing spark plugs, fuel filter and air filter (At this point the mower would not start at all):
1. Checking for spark. I got spark out of both plug wires. The modules were OK.
2. Checking for fuel flow. Only small amount of fuel coming out of fuel pump. I changed the fuel pump. (I bought a Briggs and Stratton for $22.50 instead of a Kohler for $60.00. Same fuel filter!)
It ran fine for 10 min. then quit again!
I loosened the gas cap and it has ran fine since then, by keeping the gas cap loose. I will replace the gas cap.
Note: It was difficult to find the problem, since I replaced the filter and removed the vapor lock, so it ran for awhile. I then checked the fuel pump and removed the vapor lock, so it ran for awhile. I would suggest that people with similar problems, loosen the gas cap to see if that works first!
Sep 05, 2013 | Craftsman Garden
MY KAWI ZZR 1200 WAS RUNNING GREAT ON SATURDAY. PARKED AFTER A SHORT RIDE, COLD SUNDAY NIGHT, STARTED MONDAY. HEAVY FUEL MIX ON START WITH NO CHOKE, LOADED UP AND HAS NOT RUN SMOOTH SINCE. NO POWER AND...
Heavy fuel mix is either blocked air filter or bad spark plugs, check condition of both, if nothing obvious then change spark plugs as they can appear fine but still be U/S, if problem still persists then you'll have to investigate further.
Mar 18, 2010 | 2006 kawasaki ZZR 1400
The HOT water barely trickles in . The COLD water flows great.I checked the shut-off valves for pressure, and both worked fine. The screen filters were also clean. The hoses are new and are not kinked. Any...
This is your water inlet valve that has started to go out. This is a simple repair for you to make. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your brand and model number and we will send the correct part out to you asap.
You can call us from 7 AM until 9 PM CST Monday through Saturday. We are here to help and look forward to working with you.
Happy Holidays! Ella
Nov 27, 2009 | Washing Machines
Ran great sat. but would not start sun. same gas changed plug air filter gas soaked with it off still not running tried putting gas in spark plug hole still not running this is a craftmans 2 cycle leaf...
Were you running a fuel mixture of 40:1(3.2 oz of 2 cycle oil to 1 gal of gas), that you mixed up before you started using it again. The unit may have had to much use on Saturday and may be burned up. Try to have a compression test done on the engine, needs to be at least 100 psi to run. If that proves to be good then you can start looking at Fresh gas mixture, a new spark plug, Carburetor rebuild or an ignition module.
HTH
Good Day.
Oct 26, 2009 | Garden
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Mar 18, 2009 | Garden
Chain saw emitted sparks and now does not start.
Hi
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Dec 16, 2008 | Garden
Pit SSR 110CC Pro Beginner  Bike Logo
177 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Are you a Pit Cycling Expert? Answer questions, earn points and help others
