Question about Bosch Dishwashers
How do I get inside a Bosch dishwasher? I am trying to find out what is wrong with the heater in our Bosch S210 . I can't find how to inspect the components without breaking it. What is the trick?
Just go into the bath :)
Posted on Sep 26, 2009
My dishwasher gets stuck with one minute remaining on the clean cycle until it is manually stopped. What might be wrong and can I fix it myself?
Welcome to FixYa.
Based on your description I'd say the issue actually is with the control...unfortunately. This is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated. Copy & paste this link (or click on it if it will respond) to your toolbar (explorer bar ?) and you'll see my complete solution for this issue.
http://www.fixya.com/support/t8763034-good_afternoon
I also wanted to add, depending on your model and serial number Bosch issued a recall on some of their units. Here's a link you can use to check up on your specific unit.
http://microsites.boschappliances.com/safetyrecall/dishwasher/
Good luck.
Regards,
Macmarkus :)
Jul 14, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Bosch Eexcell Dishwasher not heating. Accessed heating element by removing right hand side panel, there appears to be continuity between left and right hand terminals - where is the thermostat please and...
Hi, Welcome to FixYa. The hi-limit thermostat and NTC (all in one) are actually directly on top of the heater body, aka instantanious water heater. You'll also see a micro-switch which turns the element on once water begins to circulate, that is the flo-switch. Having said that, the issue is likely the heater relay on the main control board, specifically a burnt solder joint for the heater relay. If you visually inspect the control you'll likely see it right away. Let me know how you make out or if you need any help, good luck. Regards, Macmarkus :)
Mar 21, 2011 | Bosch Dishwashers
Dishwasher times down to 1 minute on any cycle, then continues to run at 1 minute until I turn it off manually. I have emptied out all the remaining water and completely dried out the inside. Is there some...
Welcome to FixYa.
Based on your description I'd say the issue is with the control...unfortunately.
The number"1" being displayed ( on models with the display like yours ) is actually an error code indicating a fault in the heating process.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
**B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the serial number so you may want to contact Bosch to inquire if yours is affected.**
or
Bosch dishwasher hotline 1-800-856-9226
Before calling, have the model and serial numbers on hand. A live operator can be reached at the hotline 24/hrs day.
Those not affected by the recall still can be a problem but easily fixed. As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Your control WILL differ in appearance, however the issue, the service and all the same info applies...except the part number. Yours will be # 431692**
**Flip this over and inspect the solder joints, it will be obvious when you see it...the cover for your models control comes apart in a similar manner**
This is where and what to look for, except I`ve re-soldered this one already...
...hence the unit sit`s and takes longer
Oct 19, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Some of the dishwashing soap is left and the dishes have particles stuck on them especially glasses
Thanks for using FixYa.com! This sure sounds to me like a temperature issue or a recirculation issue. The first thing I would recommend is removing the filter from the base of the dishwasher (inside the tub), 1/4 turn and it comes out. Clean the filter and the area under the large square mesh filter really good. After that, make sure you run the water at the sink until hot before starting dishwasher. If unit still not washing well and runs for a very long time, I would inspect the control for a burn mark on the heater relay which is very common on Bosch dishwashers. Start with the filter first, though.
Sep 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher model she44c02uc goes through the whole cycle and will go on and on while timer shows 1. I got to press cancel drain buttons for draining and terminating cycle. What goes wrong with...
Welcome to FixYa.
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
Sep 09, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwasher will not shut off automatically
Hello, This sounds like a very common problem with Bosch dishwashers unfortunately, that is based on your description it likely has a faulty heater relay. The "1" is actually an error code identifying a heating fault. The issue with Bosch dishwasher`s most times lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this error code "1", but not very probable ). I`d first suggest calling in an authorized bosch servicer, however If you feel capable there`s a way to visually inspect the control. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s and takes forever top finish ( because it can`t heat to advance or until canceled ) trying to heat the water. **Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)** **Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.** Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution and leave a testimony. Good luck. macmarkus :)
Apr 12, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
My bosch dishwasher is about 4 years old. It gets
Hello, This sounds like, based on your description, the unit has a faulty heater relay. The issue with Bosch dishwasher`s most times lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). I`d first suggest calling in an authorized bosch servicer, however If you feel capable there`s a way to visually inspect the control. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s and takes forever top finish ( because it can`t heat to advance or until canceled ) trying to heat the water. **Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)** **Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.** Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution and leave a testimony. Good luck. macmarkus :)
Apr 05, 2010 | Bosch Dishwashers
2h runs a long time dishes not clean
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
Good luck.
macmarkus :)
Mar 18, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
My Bosch dishwasher SHU43C02UC/38 runs the quick wash cycle in an erratic way - seems to get stuck at the last stage of the countdown ("1") and, I think, goes back up and runs again. Instead of +/- 40...
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is the purpose of the "1" indicated in the display, a heating problem.
I`d first suggest calling in an authorized bosch servicer, however If you feel capable there`s a way to visually inspect the control. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at "1" ( because it can`t heat to advance or until canceled ) trying to heat the water.
Good luck.
macmarkus :)
Mar 12, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
189 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
