Question about Black & Decker Black and Decker & Grass Hog Electric Trimmer
I require a grasshog string cutter/assemby/and screw. wgere can I order one?
  • 437 Answers
Check in your area to see if you have a Dewalt tool store in your area. They may have what you need to order parts for this unit.
Posted on Sep 26, 2009
How do you rewind the string on the black and deckder grasshog
It's annoying I know, but there should be a little notch in the spool, wind the string evenly round one groove. notch it, then do the same on the other groove but in the opposite direction. Hope this helps.
Jun 28, 2015 | Black and Decker USA BLACK&DECKER GH710...
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
Cannot get door to unlock
Remove the four screws from your dispenser, remove cover, there should be a plastic string, either red,yellow or green pull on it and the door should open. Then remove the four screws aound the door 2 aound door hinge then the other side, remove the front cover, it looks like a small goal post. Remove the the 5/16 screws under the lid. Raise top then you will see your latch assembly. oberverve your latch see if anything is broken. You can order a new latch assemby.Part#22004435 list for about $115.00
Apr 04, 2014 | Maytag Neptune MAH5500B Front Load Washer
How to change strings on vendetta
the strings on most floyd rose tremelo systems require a small allen wrench(hex head) to loosen the pressure on the bolts holding the **** end of the string in. should be easy access from the top of the guitar. hold the guitar up to your face, **** end first and look up the body towards the neck. there should be six different screw ends visible. loosen counter clockwise. you have to trim the ball end off of a new set with wire cutters in order to replace.
Feb 20, 2012 | Dean Guitars Dean Vendetta 1.0 Electric...
My grass hogger line extending unnecessarily and never get line short ( i meant extra line never get cut off. I think i have two problems here Why line is extending unnecessarily? & why it's...
If you look closely inside the shield, at what would be the leading edge as the string approaches, you should find a little cutter that trims the line if it is too long. This can get dull. I have had to sharpen the one on my B&D with a file before.
Sep 03, 2011 | Black & Decker Grasshog 12 Inch 18 Volt...
The string on my duel fed grasshog is wrapped hopelessly underneath the spinner. How do I get the thing apart?
Hi There,
Hey, it happens. But line is cheap compared to the time it may take to dismantle and then reassemble the unit. Especially if you're at a clients.
I use wire cutters and needle nose pliers to clear that birds nest quickly.
If the unit has a habit of tangling, just use less line when loading.
Call this an alternative solution.
Best regards,
Mike
Jul 13, 2010 | Black & Decker 14" Grass Hog Xp...
Need Replacement Battery for CST2000
243215-00 is the part number for the Grasshog's battery pack, but that part is now obsolete. However, you can get the internal battery (part #243213-00 )itself from Amazon for $35.99:
http://www.amazon.com/Black-Decker-243213-00-Replacement-Grasshog/dp/B0027Z7G94
Jun 28, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Remove lower clamshell from B&D grasshog NST2018 T2
Read about product details,features and reviews of Black & Decker NST2018.Check them out and order yours today!
Apr 29, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Black & Decker Black and Decker & Grass Hog Electric Trimmer  Logo
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
