Question about Emerson LC320EM8 32 in. LCD TV
Powers up but goes off
Hit power button it acts like it is comming on for about 5 seconds then goes back off, have unpluged it for 30 minutes ...didn't help...set is about 7 months old
  • 3 Answers
CHEK H- OUT TRANJESTOR 123V  123V  OK   ..................YOUR FALT  H- OUT SECTION ( REP- DT )
Posted on Sep 28, 2009
I have a D-Link DIR 300 it was working fine last week however now i can not get conection. 1 Power light is on. 2. light next to power light (with tringle in it is onand flashing. 3. the light with the...
Sometimes routers can die periodically.
You can perform a 'reset' on the router to put it back to factory settings, but you will lose everything you have configured.
To reset, press(and hold) the reset button on the back of the router (its small).
Continue to hold it for 30 seconds
Unplug the power (while still holding the reset button).
Wait 30 seconds, then plug it in again.
(Don't let go of the reset button just yet)
Wait 30 seconds after plugging it in, then let go.
Go make a coffee or do something for 5 minutes while the router does its thing.
If all goes well you'll be back at square one.
Mar 29, 2013 | D-Link DIR-300 Wireless Router
Service ticket 8017416743
Can you please confirm us the main problem you are experiencing with your printer?
Oct 22, 2008 | HP Office Equipment & Supplies
System error E000
  • Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer"
  • Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
  • Then press "Set" again, and the display will ask you "Yes" or "No"
  • Press the "Left" arrow for "Yes", then press "Set".
  • Now, unplug the power cord and wait 5 seconds and plug back in
That should clear the error. If it doesn't, get a new fuser.
Feb 29, 2008 | Canon imageCLASS D860 All-In-One Laser...
Standby light is on,but my olevia tv will not turn on.
No, someone will need to open set and check voltages etc and also look at power board to see if any puffed up bad caps like these:
Apr 18, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
I used a hdmi cable and lost cable. now cannot use av adapter no picture.
If you have absolutely no picture, hook it up with the av adapter and follow these instructions exactly: Turn your PS3 on with your remote. Note: all of these directions will be with the D-pad on your remote, joystick is not accurate. 1) If you have multiple profiles on your system, just hit X; if you don't, start at step 2 2) scroll entirely to the right. Hold your right D-pad in for about 5 seconds 3) Tap your left d-pad button exactly 7 times. 4) Hold up on your D-pad for 5 seconds 5) Press down on your D-pad exactly 11 times and hit X 6) Hold up for about a second; hit X 7) Hitt the down button 2 times and you'll be over the composite/s-video connector. RED/WHITE/YELLOW. Hit X 8) YOU WILL NOT SEE IT YET, your screen will internally read "Press the x button. The screen will be displayed based on this setting. If the setting is not correct, the screen will go blank temporarily. Then after 30 seconds the system will go back to the previous screen." HIT THE X Button now. This should have it fixed. For step 7, the first one is HDMI, hit down 1 it's component/D-terminal which is the GREEN/BLUE/RED, if you hit down 2x its the component/s-video, and if you hit down 3x it's AV MULTI/SCART. Good luck. Please give me a good rating if I helped fix your problem Respectfully, Don
Nov 03, 2010 | Sony Playstation 3 (PS3) Console
I unplugged from the wall. Now I have an error
Hai,
The Ink delivery system is malfunctioned, please perform below troubleshooting to fix the issue.
Power Drain:
1.Press the On button to turn the printer off.
2.Unplug the power cord from the back of the printer.
3.Remove all the ink cartridges.
4.Wait two minutes.
5.Plug the power cord into the back of the printer.
6.Press the On button to turn the printer on.
7.Install the ink cartridges when prompted.
If you still get the same error message (0x code on display) reset the printer.
Reset the Printer:
1.Remove the ink cartridges from the printer, close the cartridge doors.
2.Wait for 30 seconds and disconnect the power cable from the back of printer, while the printer is ON.
3.Press and Hold "OK" and "Cancel" key, while holding them, insert the power cable behind and keep holding them for 10 seconds and then release.
4.If the printer goes OFF, push ON button to turn it on.
5.Then insert the cartridges when the display prompts and check the printer.
If the 0xc18 or 0xc19 ink system error code displays on the front panel, service the printer.
Thanks & regards
Rizwan.
Jan 31, 2010 | HP Photosmart 3210 Printer
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
Jan 11, 2010 | D-Link Computers & Internet
I have no picture or sound when i hit the power button it clicks off
Please do the self check this set has:
When the power light comes on and goes out press and hold both the MENU and Input (also called Device) buttons at the same time for at least 5 seconds and then release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means and what may actually be the problem.
I am here to help people.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 18, 2009 | Mitsubishi WS-55807 TV
It takes 5 to 7 minutes to turn on my Magnavox HD TV
IFyou feel confident and can locate switch mode power supply with back removed.
Try warming switchmode power supply before turning TV on.
If TV turns on normaly then there are some small capcitors that are a common cause of this fault.
Otherwise look for DRY or CRACKED solder jointson PCB
BUT DON'T do any of the above if your are not confident send it to a TV repaiman.
Sep 11, 2008 | Philips Magnavox MS2530C 25" TV
Emerson LC320EM8 32 in. LCD TV Logo
177 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
