Question about Nikon D70 Digital Camera
D70 Shutter Stuck
After taking an image in cold weather yesterday (maybe 0º C) my shutter got stuck. It is stuck in the closed position so I can see nothing through the viewfinder. I can manually move it into the open position with my fingers but it won't return to the correct position by itself. Any ideas? I've only had the camera a few months but I bought it secondhand so I don't know for sure how old it is.
  • hannaha Dec 17, 2007
    Weirdly, it started working again after I did 'mirror lock-up' and then switched the camera off and on again. I read on another forum that cold weather can be the problem. Either way, it makes me miss my F100!
  • 26 Answers
I'm afraid the camera has suffered "shutter death". After a certain number of clicks (usually 30.000-70.000, but it could be as little as 5000 or as much as 150.000), the shutter just gives up the ghost. It's fixable, but expensive.
Posted on Dec 17, 2007
I have no image on the CD Monitor when taking a picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 19, 2010 | Canon PowerShot A610 Digital Camera
Cannot take a pic. No image in the LCD while pointing at an object or person.The LCD remains gray/black. Even if I snap a pic, no image.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 18, 2010 | Canon PowerShot SX100 IS Digital Camera
The viewer is "black". The camera takes pictures, goes through th motion, sound, but the picture is black, no image
Jun 12, 2010 | Canon PowerShot SD1000 Digital Camera
Camera won't show anything but black in the screen ... Or looking through the eye piece (canon S3 power shot) think the cold weather caused it
May 14, 2010 | Canon PowerShot S2 IS Digital Camera
Camera works but the screen went black A640 except for video and color swap. Did I press a button? I was shooting in cold weather.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
But if you've already tried this, have you also tried downloading any of your photos taken with the black screen to your computer? Are the photos also black? If so, you might instead be experieincing a stuck shutter (possibly due to the cold weather).
Jan 03, 2010 | Canon PowerShot A640 Digital Camera
Seems to be o.k. with sounds and menu screens,but no image of pic shows in viewer,and no image is recorded when transferred to computer
Oct 22, 2009 | Canon PowerShot A530 Digital Camera
I first experienced a problem with my Canon S2Is camera when it was only taking pictures of blank images. I found a "fix" recommendation which seems to have gotten rid of the black image problem. However,...
Think you need to do the fix more. Believe your shutter was previously stuck in the closed position. Now it sounds like it is stuck in the open position. Again keep trying the fix to loosen it up. Just to confirm, the "fix" you're talking about is taking repeated photos in shutter priority mode with 15 second exposures, and opening and closing the battery door while the shutter is opening, right? You may want to add some tapping of the camera against its padded usb cover in an attempt to get the shutter to jar closed.
Sep 13, 2009 | Canon PowerShot S2 IS Digital Camera
My Canon Ixus 75 will no longer take pictures.The screen remains blank and no image is recorded when the shutter is pressed. All other functions appear normal, including the display ing of previously...
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 12, 2009 | Canon Cameras
I am using canon A430 for 1 yrs bur from bfore 2 mnths when i image on day time the image becomes too bright and when i take at in light i comes parallel lines.i am beliving that u will suerly solve my...
First make sure you are taking pictures in auto, and not in manual (make sure the mode selector dial is not on the little red camera with an M). If it's not...
Now the A430 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. Repeat as the fix recommends, but please note that there may be only a small hope that this will work as the shutter may be stuck in the open position. This is harder to get unstuck than a closed shutter.
If the above doesn't work, consider attempting Fix 5a listed on the web page. There is some risk of damaging your camera with this fix, that's why I hesitate to recommend it until last.
Jul 04, 2009 | Canon PowerShot A430 Digital Camera
Screen does not show images
Jun 27, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Nikon D70 Digital Camera Logo
569 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
