Question about Maytag MDE4806 Electric Dryer
Thermal fuse or heating element problems on a medt236ayw maytag
How to gain access to see what the problem might be
  • 12smpm09 May 11, 2010
    My dryer will not give hot air.
  • 61 Answers
Remove front panel
Posted on Sep 29, 2009
  • Maytag Master
  • 7,482 Answers
Normally you will remove the back of the machine and locate the air tube that goes from the blower to the drum...the thermostats and heating element are normally located there.
Posted on Sep 26, 2009
Maytag dryer MDE9700 AYW We replaced the dryer heating element and the dryer still don't heat can anyone help me figure what parts I need
The heating element connects to a thermal fuse and then to a thermostat. The thermal fuse may be blown. There is no outward sign of failure http://www.appliancepartspros.com/01-blower-heater-parts-for-maytag-mde9700ayw.html
14 and 15 on the diagram
Jan 12, 2016 | Maytag Dryers
Maytag Atlantis Series MDE6400AYW -- Current is good, brand new power cord, drum light comes on -- When I turn the timer, I can hear it clicking, but nothing else works.
You need a thermal fuse and check the venting heat is backing up causing the fuse to blow fuse part number 307473 located on the back remove back panel to gain access
May 30, 2015 | Maytag Dryers
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag mde7057ayw not drying on intelidry
Hello there and welcome to fixya
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Dec 31, 2011 | Maytag Dryers
My speed queen aem497w is 15 years old and quit drying recently, no heat ,drum spins as usual, vent is clear , what gives ? Dave from Canal Winchester,Ohio
Hi - I am not too familiar with Speed Queens, I work a lot on Maytags, however the principals are the same.
So here goes - there is most like to be an open circuit due to the following , bad/burnt wire or terminal somewhere close to the heat elements, open circuit on the two thermostats & the over-temp fixed close to the elements, the outside chance of the thermal fuse blown.
One would noramally gain access thru the front (Best) and often from the back, sorry I cannot guide you on this as stated earlier.
Jun 17, 2011 | Speed Queen Dryers
I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Maytag Performa PAV2200
Neptune Not heating! Is there an element out or sensor?
There is a element, the thermal fuse usually opens more often, the thermal fuse is a white plastic about one inch long and half an inch wide with two wires attached. Probably a second thermal fuse located right on the outside of the heating element housing. Ohm out all and the element.(maybe 20 ohms)
Clean out the venting to prevent it.........
Do not forget to unplug unit before working on it, and check it did not accidently get put in air fluff first.....
Thinking this has a lower service panel in front to access......
Jan 12, 2010 | Maytag MDE9700AYM Electric Dryer
Maytag dryer is not heat up. I think the heating
Hello, There are a couple of variations of the heating element, depending on the series number of your dryer.
Here's a link to the parts list and line drawing so you can verify the proper element you need.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=SDE4606AYW&productCategoryId=0151200&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00005&componentDescription=REAR%20BLKHD,%20AIR%20DUCT,%20ROLLER&HTR%20(ELE)&documentId=M0510059&blt=06
If you have a Series 14 dryer, the element part number is #37001134, otherwise, there are a couple of other elements that your particular dryer might use, so check the model number and product tag so you can get the right parts.
You might want to check the element first, to make sure it is defective, before you order replacement parts, as it might be a faulty thermal fuse, which is much less expensive to replace than the heating element.
If you have a multimeter, you can check the fuse to see if it's failed. Be sure to turn the power off and unplug the dryer before removing the back access panel and checking the thermal fuse (see drawing in link above)
With the meter set to measure resisitance (Ohms) you can put a test lead on each side of the thermal fuse and if you get a reading showing no continuitity, then the thermal fuse is blown and needs to be replaced.
You can also check the heating element using the same method, again, make sure the dryer is unplugged before testing the continuity of the heating element, if you don't get a continuity reading, then the heating element is bad too.
I hope you find this Very Helpful and best regards!
Nov 13, 2009 | Maytag SDE4606A Electric Dryer
Maytag dryer mde7500azw does not heat
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
Below are some points for diagnosing the problem. First, ascertain that you have made a positive heat selection on the control panel switch, then proceed if that does not help. There are more components involved which could create a No Heat issue, but these are generally very rare.
If your dryer doesn't heat, check these most common issues:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
You can also obtain more appliance information at my website, www.homemanagement.services.officelive.com
Aug 28, 2009 | Maytag Dryers
Heating Element rattling
I would not run the dryer and check the wires to the element and make sure there are no burned wires. I would also replace the heating element. It should not be loose in any way
Jul 27, 2007 | Maytag MDE2600 Electric Dryer
Maytag MDE4806 Electric Dryer Logo
150 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
