To delete photos in 1st generation ipad tap photos,tap photos again then tap photo you would like to remove.When in full mode trash can is available. For 2nd generation and new ipad,tap photos then edit.Tap each photo to add check then tap delete to remove all checked at once.Please Rate
As a matter of fact, every time you sync data between iPhone 3 and iTunes, all previous data will be automatically backed up by iTunes and stored as a .sqlitedb file, which will be updated along with the later sync continuously. But those backup files can't be viewed or taken out unless you use some software using special algorithms to extract.
Yes, it is possible to recover deleted iPhone SMS messages by touching the iPhone mistakenly without backup.
Recover deleted or lost SMS messages with iPhone SMS Recovery tool!
For iPhone 3G/4 users, you can directly recover your lost SMS message back even without any iTunes backup with the help of this world's first iPhone SMS Recovery tool! Just follow the steps !
As a matter of fact, every time you sync data between iPhone and iTunes,
I found this solution posted as comment on this clip:
This following solution was suggested on youtube, it worked for me. There is one negative point about it: ALL YOUR OLD MESSAGES WILL BE DELETED
If you delete your sms.db file (located in: var\mobile\library\sms) it fixes it, you can open and send\recieve sms. i think the only permanent solution is to upgrade to 1.1.3 with itunes and start again (im asuming u got the bug using ziphone, i did). i installed isms as a backup sms service incase it stops working, which it does often. you cant look at recieved messages, but good for sending sms if sms.ap is playing up
Tenorshare iTunes Data Recovery is a great and professional iPhone data recovery tool for you to recover iPhone data you deleted or lost even your phone is broken or stolen. It takes a good advantage of the iTunes backup file.
By using this software, you can recover deleted or lost photos, videos, music, contacts, text messages, notes on iPhone 5, 4S, 4, 3g and save them to your computer safely and easily. What's more, it even enables you to recover iPhone data without iTunes or your phone! You can get it from http://www.any-data-recovery.com/product/itunes-data-recovery.htm
