Question about Frigidaire Ovens
Oven wont light
Igniter lights oven wont
    President:
  • 1,015 Answers
If the igniter is lighting it is either the gas control valve is sticking or the igniter is not reaching the 2200 degrees to open the gas valve. What you can try to do is turn on the oven and watch the igniter glow. Then you can use a wrench or screw driver and tap the gas control valve. If the burner igniter comes on then the control valve was sticking. After it comes back on shut off the oven and try turning it on and off again several times. If it comes on and off right away then you may have fixed the problem by loosening debris in the valve. If it does not come back on again then you will need to test the igniter with a fluke meter. It should read at least 500 to 700 ohms. Most places that sell replacement igniters can test it for you. If the igniter is testing goo then the gas control valve is sticking and needs replacement.
Posted on Sep 26, 2009
  • 6,784 Answers
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils(This will be the next possible issue if the igniter is functional)
Westinghouse px 650 gas wall oven wont re ignite once initial heat is met
what you should be doing next is to get a gas fitter out to determine why the pilot light is going out or the sparker is not lighting the gas
gas is not a diy operation as a mistake from you could destroy the building and yourself
Dec 15, 2016 | Ovens
Oven wont light up but igniter is glowing and top burners are working good
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 05, 2011 | Ovens
My oven wont light . i had to slam door to get it to light and now it wont light at all
You need to get the igniter replaced. Don't mess with gas. Get it fixed.
Apr 21, 2010 | Ovens
OVEN WONT WORK
Even though the igniter is red, if you are not getting gas it is almost 100% sure that the igniter is simply not getting hot enough. A new igniter should get that valve to open and you will be baking like crazy.
Nov 30, 2009 | Maytag CWG3100A Gas Single Oven
Oven will not light. burner won't even light if I try lighting it with a lighter. I thought maybe it was the igniter but am wondering if the burners go out on these. This is a problem that has been getting...
Oven not Working or Oven not Heating
heatman101
fdfsd
Jun 29, 2009 | Magic Chef 9122 Gas Single Oven
Pilot Light Wont Light
Take off the top cover plate inside the oven. Now with the door open turn the oven on does the hot surface glow? If it doesn't glow then you have a bad igniter and needs to be replaced. What ever you do don't touch the surface of the new igniter human oil will shorten the life of the igniter. now if the hot surface glows then the gas valve is bad and need to be replaced. I'm betting it's the hot surface.
Nov 25, 2008 | Amana Ovens
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
Oven wont light
My Amana oven will not light, the electric ignitor comes on, but it will not ignite the burner for it to come on. What do you think the problem may be?
Jul 22, 2008 | Ovens
The clock & oven on my cannon chichester cooker dosent work
Hi anyone , my chichester ignition button has stopped working - is there a battery located somewhere
Dec 05, 2007 | Ovens
Ovens Logo
192 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
