Question about Eureka 2961AVZ Bagless Upright Vacuum
How do you take the vacuum apart to replace the belt
  • 701 Answers
Here is a link to the belt you need and to the manual which has instructions:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Posted on Nov 19, 2009
Sebo felix belt is broken,taken screws from bottom of vacum but will not come apart
There are actually two belts on your Sebo, one that drives the brush, and the second that attaches to the pulley on one end, and the motor shaft on the other. I'm assuming that the belt you need to replace is probably the brush belt, or the belt that attaches to the brush gear on side, and the pulley on the other.
Here's what you'll need to do:
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment..
Oct 13, 2012 | Sebo Felix Ice Blue Bagged Upright Vacuum
My Bissell 3130 Easy Vac Bagless vacuum makes a "rev sound when pulling back on the vacuum, never did this before i have taken apart and cleaned vacuum thoroughly, not sure what else i can do
The drive belt may be wornout/stretched and the act of pulling the vacuum backwards could be causing the belt to slip and the motor to rev up as a result.
Do you have a replacement belt you can try?
Jan 05, 2011 | Bissell 3130 Bagless Upright Vacuum
No suction
You have a clog somewhere in the vacuum. Check the hose and the little trap door on the underneath side of sweeper.
Does the brush turn? If not, then the belt that drives the brush is broken. Replace the belt
Jim
Jun 08, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Broken belt
Hi.
If you cant easily see how to replace the Belt then I think your Dc07 has A clutch unit.
This type of Dc07 has 2 belts one from motor to clutch & the second belt goes clutch to brush roller.
You will need to remove the clutch unit completey from the machine in order to replace the belts, Its alot to explain so try this site it has service manuals covering this.
http://dysonmanuals.llc.nu/
Jul 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Kirby g5 vacuum
Either the cogged belt broke, or you will have to pull the transmission and see if something came apart. May have to replace the transmission.
Jun 01, 2008 | Kirby G5 Bagged Upright Vacuum
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
How do you take apart a hoover brush n wash to replace the belt
Generic problem for all Vacuums
How do you take apart?
How do you take apart a Hoover brush n wash to replace the belt?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
On a Hoover brushroll there are 2 types, wood and metal, and the metal can be washed with water and the wood should only be wiped off, knowing the name brand of the vacuum most of the vacuums the belt change is done by removing the bottom plate and exposing the belt, 1st hook the new belt around the brushroll and then use a screwdriver or similar with a bent hook on the end and then pull or hook the belt on to the motor pulley and then track the belt to make sure the belt stays on, then re-install the bottom plate and turn the vacuum on to test to see id the belt was installed correctly. The other is to look for 2 or 4 screws on the bottom and then remove the top cover and follow the instruction listed above without the bottom plate. A belt change should be done every 4 to 6 months on regular basics and to keep the belts in the refrigerator to keep them fresh.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
www.A-1Vacuum.com 1-800-657-1874
Apr 21, 2008 | Vacuums
Hoover upright vacuum information
cant help with manual but if i may why would u take it apart theres not much to service but to take the belt off turn the machine over and down by the roller there are a few screws take them out the cover should come off and thats it
Sep 26, 2007 | Hoover Elite U5061-900 Bagged Upright...
Eureka 2961AVZ Bagless Upright Vacuum Logo
312 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
