Question about Nikon COOLPIX L10 Digital Camera
Nikon L10 has developed a flickering screen overlay (zoning lines or actions such as alter flash priority) When trying to close off the menu overlay a section of it remains and obscures the view from the lens. When a photo CAN be taken the image stays on the screen until the camera is forcibly shut down. The photo IS saved but all this makes a helluva nuisance to use.
  • 3 Answers
SOURCE: black screen when in picture mode cant take pictures
PER007 in solution #3 is correct.
  • Follow the URL: http://www.nikonusa.com/email_images/nikonusa/service_advisory/launch_all.html
  • Fill out the form
  • Mail in your camera if it's listed
  • Receive your working unit free of charge
I had the same problem with my CoolPix5400 and this resolved the issue.
Posted on Dec 23, 2007
  • 104 Answers
SOURCE: Black Screen
sir,u replace ur camera CCD
Posted on Apr 11, 2008
  • 19 Answers
Did you leave it in the sun . Or in a hot place ? Was it wet in any way ?
Posted on Aug 18, 2009
SOURCE: My Nikon D40 LCD Screen doesn't show a live view
the d40 does not have live view. you would need to get a different camera.
Posted on Nov 26, 2009
  • 11967 Answers
SOURCE: nikon coolpix s230 lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 19, 2010
How do I turn off the flash
Lots of cameras won't let you turn off the flash in Full Auto mode. Trying changing your camera to Apature Priority ( A, Av) or Shutter Priority (S, Tv) or Manual (M) and see if the option to turn off the flash appears in the menu.
Nov 15, 2014 | Nikon COOLPIX Cameras
I have nikon L10. The flash does not work. But it works if I click using self timer
Try this link below and check if this is the case.
Click here -> Nikon L10 Troubleshooting
If that does not help you, try the steps below
Click here - > Alternate Method
Regards,
Suhail
May 15, 2012 | Nikon COOLPIX L10 Digital Camera
How do i turn on the flash for the nikon coolpix L10
Click on the top of the dial to the right of the screen (where it shows a flash of light logo). This should allow you to select one of the different flash settings - always on, always off, auto etc. Study the manual about what each of those mean for more details.
Dec 24, 2010 | Nikon COOLPIX L10 Digital Camera
I have a Nikon COOLPIX L10 Digital Camera and flash is not working in any mode.i changed batteries but it still not working.please help.
there is a possibility of flash bulb is not functional. or it may happen due to connection between flash lamp and battery has disturb.... So best way is to get it serviced......
Apr 30, 2010 | Nikon COOLPIX L10 Digital Camera
Coolpix L10 . Flash is'nt work it. I Cant not Flash when i taking a picture.
did you tried to activate it from the menu ?? and see not to be in conflict with other settings..like flash off ...or whom knows...
Aug 01, 2009 | Nikon COOLPIX L10 Digital Camera
From where i can replace my Nikon L10 LCD screen, which has gone white, I am unable to view anythig from the screen..
I suggest you contact Nikon support and ask where is the nearest service center so they can replace your LCD screen. you can find contact information of Nikon support in your country athttp://imaging.nikon.com/products/imaging/worldwide/index.htm#americas hope this helps
Jul 08, 2009 | Nikon COOLPIX L10 Digital Camera
Flash went out
you have to replce flash lights at nikon service center,that is only solution
Aug 07, 2008 | Nikon COOLPIX L10 Digital Camera
My Nikon Coolpix L10 dose not want to turn on.
My daughter has a coolpix L10 that had a similar problem. Try this:
Put the camera in movie mode and turn it on. Press the menu button and go to setup. Go to the battery menu and make sure the correct battery selection is made (i.e. Alkaline, NiMH, etc.) She changed from alkaline batteries to rechargeable NiMH and the camera would do the same thing you are describing until we made the correct battery selection.
Feb 22, 2008 | Nikon COOLPIX L10 Digital Camera
Nikon Coolpix L10 screen replacement
Try visiting here:
http://www.advancecamera.com/repair?k=nikon&gclid=CN71rpOKo5ICFQERPAod4W4pRQ
and getting a quote from them.
Dhalgrin
Oct 27, 2007 | Nikon COOLPIX L10 Digital Camera
Nikon COOLPIX L10 Digital Camera Logo
24 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
