Question about Dryers
I am buying this washer and dryer combo which is going o be installed in a mud room which is in the process of being built. My electrician and plumber need the specs for the wiring and venting of this product can you help me get this info for them thank you in advance g may LG dryer and washing machine front loader DLE2301w and WM2301HW
    President:
  • 1,714 Answers
Dryer surface too hot to touch
this dryer is an electrical heated dryer i suppose, ask an electrician to check the heat sensor, for this should trigger the on and off switch of the heater according to the drying cycle you set your dryer.
Dec 07, 2013 | GE DSKP333ECWW Laundry : Washer/Dryer...
Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Feb 05, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Replace a washing macine FWT449GFS1
Not really, you need a front load washing machine, any kind, tell the store you will put a dryer on the top, and they will give you a installation
kit.
Mar 21, 2013 | Washing Machines
Can I install this in my house?
Hello buckeye,
In a word...Yes.
There actually aren`t anything different about most rv appliances, with the exception of gas/absorbtion fridges. As far as the "Splendid" brand washer/dryer combo, they are just an "equator/bendix" with a different badge and a little more compact...harder for me to work on is all, no elbow room, hah ha !
The water inlet lines, power cord, and drain are all the same. ( unless someone has changed them ).
Hope this answer`s your question. If you are satisfied with this solution please rate it accordingly. Thank you for visiting "fixya" and good luck.
macmarkus :)
Apr 06, 2010 | Splendide 2100 Vented Washer-Dryer
Washer location
Not advisable. Garage area would need to stay above freezing temp., and dryer performance will be poor at best if intake air is below 50 F. If you are not doing a lot of laundry, you can use a combo unit. (washer and dryer in one unit. LG makes one, others must also) They are slow, as the dryer is only 120 volt, and dryer does not work well with over a half load, but they also do not require an outside vent, and only require room for one unit, instead of a seperate washer and dryer.
Nov 09, 2009 | Washing Machines
Longer cord/age of washer & dryer
Is your dryer electric with the big plug.
If so, what kind of changes are you making?
The dryer needs to be by the vent outlet so you can't move it far unless you are going to cut a new venting outlet.
If it is electric (not gas) then do not try to extend the cord. Have a licensed electrician move the electrical jack.
The cord has a large amount of current running through it and the longer the cord, the more resistance the current has to flow through. More resistance means more heating of the cord and less voltage for your dryer. This can result in the cord overheating to the point of melting and starting a fire itself or getting hot enough to ignite the very fine and very dry lint particles that are present in any laundry room.
This is a situation where you spend the money and have it done professionally because of the danger of fire, death, etc.
Good Luck!
Oct 09, 2009 | Dryers
I have a zanussi turbo dry built-in washer/dryer built-in 1200, Mod zjd . 125, and I do not know how to use it. HELP! Thanks, Cindy
Hey, Just load the washer but do not over load. These combo washer dryers are strictly for smaller loads. You should have a drawer to the left that you place the soap and softer and bleach. Set to the washer to washer. The door should lock automatically. Then set your dryer setting to the the Heat temperature that you want. 100 degrees is ok to start with. then it will adjust itself as it goes through the cycles you have set. Enjoy the machine should work. If it does not look to make sure that the door is closed all the way. Sometimes you have to open the door and reset it and shut the door or while it is closed gently push on it till you hear a small clicking noise. ENJOY YOUR WASHER DRYER COMBO
Aug 28, 2009 | Washing Machines
Installation of washer/dryer combo with no taps available
hello you can buy washing machine taps that screw on to the main water pipe. what to do is turn your water supply off at the stopcock and get the your new tap and clamp it on to the water pipe and tighten it up.it will make a hole into the pipe and to the same with the other 1 when your done turn water supply on make sure you have no leaks good luck
shaun
Mar 28, 2009 | Haier HWD1000
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
My electrician installed the 220 outlet for my dryer on the floor in my laundry room. Is this a hazard if I ever have a water leak from my washing machine? Should I have him reinstall it in the wall?
I for one would have hadthem install it into the wall. However, if he was a licensed electrician then he would, BY LAW, have to follow building and electrical codes for your area. Contact another electrician and ask them how they would have done it.
Apr 08, 2008 | Dryers
Dryers Logo
113 people viewed this question
Top Dryers Experts
