Question about Viking Refrigerators
Viking Refrigerator VCBB362R freezer back panel has black and yellow wires connect to terminal with ? fuse. Do you know the correct orientation of these wires?
ghappliances
  • 126 Answers
SOURCE: VIKING FREEZER FROST BUILD UP
DEPENDING HOW OLD THE UNIT IS YOU MIGHT HAVE A BREAK DOWN IN THE INSALLATION ON THE SIDE WALLS OF THE APPLIANCE.ALSO CHECK THAT THE DOOR SEALS ARE SEALING OK IF ITS A BREAKDOWN WITH THE INSALLATION THAT MIGHT BE A COSTLY REPAIR BUT GET A TECH TO GIVE ADVISE.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
woodchuck789
  • 4070 Answers
SOURCE: Viking refrigerator with bottom freezer always running
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Jul 05, 2009
  • 121 Answers
SOURCE: Freezer compartment is OK, But refrigerator is
sounds like your thermostat may be bad . the thermostat senses the tempreture in the fresh food section and turns the ref. on and off as needed . do it yourself roughly 39-89 dollars if u hire a proffesional around 95.00- 165.oo depending on were u live and who u use.hope this helps
Posted on Oct 06, 2009
SOURCE: The freezer has quit freezing. The refrigerator
your refrigerator 100% depends on the freezer (unless you have a sub-zero brand fridge, that has 2 compressors). So your fridge will be warm soon too. There is no fuse in the fridge. Try unplugging it for 24 hours and see if that helps, otherwise it's better to call for service.
Refrigerator repair orange county, ca
Posted on Feb 06, 2010
heatman101
  • 43501 Answers
SOURCE: Viking Refrigerator stopped cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
I have a 220V circuit (1 black wire, 1 white wire, and one green ground wire. The new stark industries pool pump has three terminals plus a ground, There is one terminal for a black wire (terminal A) and...
First, be absolutely sure that your motor is wired for 220v. If it is 110v and you apply 220v the motor will die instantly (after a loud bang). Also verify that your supply is in fact 220v.
Without exception 220v power should be supplied by two wires of the same color, as they are both "hot". Black and white wires are common in 110v wiring, the black being hot and the white neutral.
Every pool pump I have worked on has had two terminals where the wires attach to the motor, L1 and L2, wire orientation does not matter.
Evidently yours only has one. Apparently there is no wiring diagram on the side of the motor either, which is also atypical. Best bet is to call the factory for assistance with this.
Dec 22, 2013 | Pool & Spa
Defrost Problem - evaporator completely frozen
i know i think in the fridge part (atleast on mine) there is a knob for temp.
if that doesnt work i guess you need another defrost terminator
Dec 13, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Replacing Pool pump motor
Which control panel?
White can be Com, and Black Lo, and Red/Blue Hi
But this is guessing without knowing control panel wiring.
For example T106 timer. Wires can be any color.
http://waterheatertimer.org/images/T-106-control-208-277V-4-40.jpg
High connects to terminal 4
Low connects to terminal 1
Com connects to terminal A
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 16, 2013 | Pool & Spa
This unit comes with a Four Conductor Cable to hook up power in. How are these four conductors hooked to power?
Disconnect the battery. Connect the green wire to the Negative terminal.Put a 20a fuse inline on the black wire and connect to Negative terminal.Put a 20a fuse inline on the red wire and connect to Positive terminal.
Put a 1a fuse on the yellow wire and connect to ignition switch - if you don't want to use the Ignition Sense feature, connect the yellow wire to Positive terminal.Re-connect the battery and test.
Nov 11, 2010 | Motorola VC5090-MA0QM0GH6WR Wireless...
Jul 05, 2009 | Viking VCBB363L Bottom Freezer...
DFSB483 Side by Side Inlay Viking Refrigerator not cooling
The unit should not need to be pulled out diagnose it.
At the bottom on the rear inside wall of the Freezer can you see any signs of frost build up?
If there is then it is more than likely the defrost terminator
When you open the freezer door can you hear the fan blowing in the freezer?
If not then the Evaporator fan could,be bad and need replacing.
If there is no frost and the fan is running, try turning the unit off and then back on, the power off switch is accessed by removing the center grill of the top grill. There are 2 switchs in this compartment. If you flick the switch and the lights stay on this is the wrong switch, flick it back and find the other switch, power the unit off and then back on. What you should here is first the fans come on followed by the compressor, it will take about 6mins for this to happen. If the compressor is running and you have no cooling then you have a sealed system issue and you ned to get a certified personnel to come and make the repair.
Jan 15, 2009 | Viking 48 in Built In Professional...
Malfunctioning Garmin GTM 20 fused GPS power adapter
The two red wires are +VE Supply and both connect to pins 1 and 2
The two brown wires are Supply Ground and both connect to pins 8 and 9
Pins 3 through 7 are the traffic recievers digital interface:
Purple/violet connects to pin 3
Yellow connects to pin 4
Blue connects to pin 5
Black connects to pin 6
Green connects to pin 7
Dec 30, 2008 | Garmin GTM 12 FM TMC Traffic Receiver...
Viking beeping
do you notice alot of ice builup on the freezer back wall? if so you need to defrost it and more than likely replace the defrost terminator. make sure you remove the back panel and use boiling hot water to remove the ice( i normally use a coffee cup) part # 10442407 ONLY USE VIKING PARTS) others may tell you to use whirlpool or some other but DON'T
Mar 29, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Model TFX22ZPDAAA GE side by side
It's usually the defrost heater on this model. Pull rear panel of freezer and remove the heater, (2 screws). It's at bottom of coils. Take to your parts place and they should be able to ohm out for you to see if it's ok. If it's all blackened, probably heater.
A check you can make is to pull refrigerator out to access back. UNPLUG UNIT!
Remove panel over control board on back of fridge. On the blue connector in bottom of board note the defrost terminal as specified on board. Unplug connector and put a jump wire from this terminal on the CONNECTOR, to the terminal that has the wire going to it with no wire next to it. Plug in refrigerator. If defrost heater is good, it should start glowing red within a few minutes. If it doesn't replace it.
Nov 12, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
65 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
