Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I get an F1 fault code during the fill cycle. Can anyone help us?
Our whirlpool WTW6-400Sw1 washer gets an F1 fault code during the fill cycle. What is it's problem
  • 15,935 Answers
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    F1 flashes on my maytag bravo washer
    This is an inherent problem with this Whirlpool-made top load washer and at first it is believed to be a machine/motor control fault. But it was found later that it can be due issues associated with the pressure transducer/switch system. Air leaks and moisture in the pressure hose including lints or flashing in the air dome can lead to signal error being sent to the machine/motor control assembly and it is interpreted as a machine/motor control fault. You may also observe that the fault code F1 appears usually during water filling at the start of the wash cycle and/or at the start of the rinse cycles.
    Check the pressure hose for air leaks and moisture including the air dome. Replace the machine/motor control assembly if no issue is found with the pressure hose and the air dome. Click on the link below for the troubleshooting and repair instruction details.
    Troubleshooting Fault Code F1 on Whirlpool Cabrio, Kenmore Elite Oasis, and Maytag Bravos Top Load Washers
    Jun 17, 2011 | Washing Machines
    My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
    F1(F68)-Pressure Signal Out-of-Range
    I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
    Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    While filling it will flash an F1 code and stop. If I cancel the cycle and press start again it will usually go ahead with that cycle until the nest fill up. What is an F1 code?
    This is a pressure sensor issue on the machine control board .The only sure fix is to replace the machine control board which has been updated numerous times.( whirlpool is very aware of the problems) At one time whirlpool was assisting owners who had this concern .
    Sep 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Our Cabrio Washer shows a F1 code during operation? Can yo help us with this problem? John & Kathy
    Hi
    Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. To remove and replace the control you’ll have to unplug the washer and then remove
    three screws from the rear of the console assembly. Pull console towards front of washer to hinge open and/or remove console. Then remove the one screw holding the machine/motor control assembly to the console tray and two plastic legs on the rear of the machine/motor control assembly that fit into the console tray. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Jun 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    My Whirlpool Washer Cabrio model# WTW6200SW has a F1 error (fault) code? Does anyone know what this is and how to clear/reset the code?
    Called 1-800-253-1301 was told by the Whirlpool agent that there was a quality issue associated with the F1 fault code. They would take care of parts and labor free of charge! My machine is 28 months old. Talked to a woman named Valerie.
    Mar 18, 2009 | Whirlpool WTW6400SW Cabrio Washer
    Whirlpool Cabrio Washer Error message code F1
    Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
    On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
    1. Disconnect the power
    2. Gain access to the back of the ERC
    3. Disconnect the ribbon cable that connects the ERC to the touchpad
    4. Check nothing will short when power is reconnected
    5. reconnect the power and switch on
    6. Watch for F1 and listen for the beep
    7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
    8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
    Feb 13, 2009 | Whirlpool Washing Machines
    Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
    hi my name is joyce
    Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
    now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
    thanks
    joyce
    Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Washer stops with an F1 Code during rinse cycles.
    Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
    Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    37 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
