Question about Panasonic VDR-D200 DVD Camcorder
After finalizing a two sided disc, only one side will play on my DVD player.
SOURCE: Unable to Finalize Disc/Finalize Option Blacked Out
Just by plugging it into the charger it worked for me. I am guessing that it does not finalize until you plug it in just in case the battery level is low.
Posted on Nov 22, 2007
SOURCE: finalizing and reading discs
throw that camera away. get a sony
Posted on Nov 23, 2007
  • 10 Answers
SOURCE: Mini-DVD playback
two things:
1) connect the camcorder to your computer using a USB cable and play it through that, by the way, what computer is it?
2) you can finalize without the ac adapter - its a built in safeguard to ensure that there is enough power to allow finalization to complete
Posted on Aug 06, 2008
SOURCE: "FInalize" menu option greyed out on my Canon HR10
works!  Cannon FAQ stinks and never mentioned it.  Thanks for posting the solution!
Posted on Oct 09, 2008
SOURCE: How do I "finalize" the DVD video so it can be copied and played
Finally...was able to get to a copy of the owner's manual. I knew it would be a simple solution, just needed to get to the instructions.
Thanks!
Posted on Dec 15, 2008
Can the DVD player be played while on it side.
Yes it will play on it's side after the disc has been clamped in the player. If the disc tray is not designed to be upright then the disc will fall out when you open the tray
Sep 09, 2014 | Cyberhome Televison & Video
My dvd player plays dvd discs ok. but when i use dvd burned on my computer shows no disc.the same disc plays fine on my computer
Some DVD and Blu-Ray players will not play a burned disc until it has been finalized. Finalize the disc on your computer then see if it will play. (Finaalizing a disc means it can no longer be recorded to, by the way.)
Aug 27, 2011 | Samsung BD-P1500 Blu-Ray Player
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
Jvc dvd/vcr player records from vcr to dvd but only plays back the dvd on the jvc DR-MV79 won't play on any other dvd players
Have you finalized the DVD in question? Unfinalized discs usually won't play in other machines. Is the DVD type compatible with the other dvd players? (Some may not handle DVD+R for example; it is an acceptable disc for the jvc DR-MV79.) Try a different brand and type of DVD. Check your other players supported discs.
To Finalize the disc, Menu > Setup > Disc Setting > Finalize (if needed set Disc Protection to Off).
I hope this helps.
Dec 25, 2010 | JVC Televison & Video
MY DVD R DISC WILL NOT PAY IN MY DVD PLAYER - I HAVE A SONY DVD CAMCORDER BUT THE DISC WILL NOT PLAY ON MY DVD PLAYER
Please finalize recorded dvd disc in camcorder then it can be playback in any other dvd player.
Disc finalize option is available in camcorder disc menu.
Thanks.
Sep 09, 2009 | Sony Handycam DCR-DVD403 DVD Camcorder
CD's won't play in other machines
Your problem is an easy one.....you need to "finalize" your completed/burned CD first...then it'll play in tray A...and others. Good luck....from Middleman
Feb 07, 2009 | RCA CDRW120 2-Disc CD Recorder
DVD will not finalize
I have a Zenith XBR413 that I have a problem with when I copy from VCR tapes to DVD-R discs. After I copy them, I can finalize the disc using the SETUP button on the remote and then choosing the very bottom disc icon at the bottom of the menu screen. It then leads you through the finalization procedure. But the disc will still not play on any DVD player but the XBR413
Jun 29, 2008 | Zenith XBR716
Directed 9" Model OHD901 Power comes on, lights will come on, screen shows AV1 & AV2, but will not switch to DVD screen, and will not play dvd.
Preliminaries: (call Directed if these fail at 1-800-274-0200)
Make sure the disc format is supported - not HD, not Blu-Ray, and not an unfinalized burned disc
Make sure the lock switches are firmly in place
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off.
Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE)
Press the (SOURCE) button on the remote or momentarily press the POWER button on the left
side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting:
DISC does NOT Play
Parental code is set lower than than allowed by the DVD mounted.
Ensure the disk is mounted in the player with the correct orientation (shiny side up).
The disk is warped.
The player cannot play certain formats (see the beginning of this manual).
The region code on the DVD does not match the player.
Moisture condensation has occurred within the player. Leave the unit on and the disc access cover
open and try again after about 30 minutes.
The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came
with your disc authoring equipment.
May 23, 2008 | Televison & Video
Directed 9"Model OHD901: Power comes on, lights work, screen shows AV1 and AV2, dvd will not play at all
or
SOURCE (MODE)
DISC does NOT Play
The disk is warped.
Finalizing both sides
A Dual Layered (DVD-R DL) disc has two recording layers on the same side of the disc. No recording is made on the 'other' side of the disc.
Finalising the disc will finalise both layers. Most probably your computer DVD drive cannot read both layers of the DVD-R DL disc. DVD-R DL discs can only be played back on DVD devices that are compatible with dual layered discs.
Check your computer DVD drive spec to see whether it can read DL discs.
Mar 19, 2008 | Canon DC210 DVD Camcorder
Panasonic VDR-D200 DVD Camcorder Logo
70 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
