Question about Brother MFC 210C All-In-One InkJet Printer
I have no red ink showing up and its a new cartrige it shows full on ink monitor.
5 Suggested Answers
SOURCE: brotherMFC-235C status monitor shows ink is empty,but its new ink,and wont print
we called asus and we had to delete a filter in the main program.problem now solved.
Posted on Oct 08, 2008
  • 43 Answers
SOURCE: red will not print after cleaning several times
There may be a problem with the printer's mechanism, electronics, or even the software. You should probably contact the company, and explain the situation. Presuming you have an internet connection, they may be able to correct the software via your computer, over the internet. You'll just have to allow the company access to your machine.
Posted on Oct 22, 2009
SOURCE: Brother MFC-420CN keeps showing Unable to Print w full ink
I often have the same problem - The inks being put into the printer are seated very sensitively. The lever holding them in may be also acting as a pressure sensitive switch because when I wiggle it a little, the printer usually starts working again! Make sure the cartridges are pressed STRAIGHT DOWN, wiggle them and wiggle the plastic pressure lever. (I do not know what else to call it!) and I hope yours works again. It is a great little printer, but this is really annoying! Good luck!
BTW, if your inks are RE-FILLED, that may be your problem. It seems they are made to NOT be refilled. To avoid this problem, do not wait till they are empty to refill them. Check them monthly (depends on usage) and when they get 1/2 way, refill then. Do NOT put the hypodermic refilling tube in deeper than necessary to refill. I use a heated nail to make my hole in the plastic, going ONLY in as far as necessary to make the hole, and then I cover it with scotch tape. Then I wash off my hands with Lava soap! (Haven't mastered the knack of not getting the ink on myself, yet!)
Posted on Apr 27, 2010
Samyfam
  • 379 Answers
SOURCE: new black ink cartridge showing full but not
This could be several things, some of which may mean your machine will have to be repaired by a Brother agent (probably cost you more than a new one), and/or it's time to bin it.
However, sometimes it's just because the print head, or the pipes that connect the ink tanks to the print head, have become blocked with dried out ink.
If you search on YouTube, you will find a few videos that show how to clear such blockages - you may not find your exact model number, but many Brother machines use almost identical components to many others so the basic technique will be the same. Also search on Ebay for printer cleaning/head blockage kits - quite a few printers (not just Brother) suffer similar problems and a few businesses have sprung up on EBay that sell kits to help you sort this. They sometimes have links to a video they have produced showing how to use the kit which can give you ideas. Again, your exact model number or even make might not come up but these kits might be adaptable to your machine. Got to be worth a tenner or so before binning it ! Good luck
Posted on Oct 01, 2010
Eroor ink out ebson t1100 series
If your cartrige is origanal, Please change that cartrige which show cross sign on your monitor,
If not, Please try to clean the cartrige's connector. ( for CIS)
Thank you
Jun 01, 2013 | Office Equipment & Supplies
My lexmark 5600-6600 reading low ink. Yet they are brand new cartriges. What do I do?
Take a small piece of clear tape. Try covering one of the outside vertical row of contacts at the front of the cartridge. Re-insert it and it should force the printer into thinking it is a new cartridge.
Ink now shows with question mark but reads as full and prints fine.
Regards,
katharsys_i
Mar 03, 2011 | Office Equipment & Supplies
Printing blank paper
At a guess you've bought a compatible generic cartrige. I had a similar problem different printer.
I had to by a genuine cartrige, worked fine. Contacted the generic cartrige provider, explained the problem. Returned cartriges and got refund no problem.
It looks like the generic cartrige makers are seeing some solutions to chipped cartridges but not all.
Mar 13, 2010 | Dell 922 All-In-One InkJet Printer
U130 ink message on pixma mp620
Very simple solution: When the pixma mp620 screen shows error U130, Hold down the stop (red triangle) key for about 7 - 10 seconds. This overrides/turns off the ink monitoring function. The printer will begin "thinking" for a bit and then start printing. Note: you may have to do this seperately for each color. You'll also notice that when the lid is open and the cartridges are in position for changing, the cartridges that used to be "out" are no longer flashing red, nor a stead red. They are dark.
Feb 17, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Put in new ink and it still won't pick up the pink and maroon. When I print the red tones they look yellow cause these cartriges arn't being used. How do I get the printer to grab these colors. It won't...
You must perform the "clean head" utility.
Go to
[Start]
[Printers and Faxes]
right-click on your printer and select [Properties]
[Maintenance] tab
Clean print head or other maintenance utilities.
You may have to do this 2 or 3 times.
Oct 11, 2009 | HP Photosmart C6280 Printer
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
Ink tank empty display will not go away
Go into Brother printer control centre and bring up brother staus. Shows all the colour levels.
Next lift printer cover up and remove carefully the cartridge that is showing empty. replace carefully making sure it is all the way in. On the printer panel push INK MANAGEMENT. scroll through until you find clean. make sure cover is back down and press clean of the particular cartrige you are having a prolem with. ei BLACK press clean black. On the Brother status monitor on your PC you should now see that the black is full
Aug 04, 2008 | Office Equipment & Supplies
Photosmart 3300 will not print black ink new cartrige. Self test failed,prints colours OK. page count 2698 Began problem perfect print top of page,fainter and blured as printed down page, replaced...
Take a dish- put damp tissue in it- if it can a one of the alchohol based cleaning tissue fine.
Stand the cart init for 10 minutes.
with a similar tissue give the contact sheet a wipe. and if it is flush to the bodty see if it has some give.
Reinstall and try
Jul 16, 2008 | HP Office Equipment & Supplies
Lexmark C500 Error light showing,with New ink cartrige inserted showing toner low replace cartrige on machines display? Help!! thanks
Remove the cartridge, take a flashlight and check the right side inside the printer for a RED LED (in the place where the cartidge stays). Take a tape and patch that LED. That's all ! Enjoy
Jul 02, 2008 | Lexmark Office Equipment & Supplies
Brother MFC 210C All-In-One InkJet Printer Logo
21 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
