Question about Coleman Gas Grill Stove
Generator sizing Is there much difference between a 425f,426e and a 413h generator?
  • 832 Answers
Yes, there is. the difference is in the feature that each
have.
Posted on Sep 26, 2009
Why would a Dometic 13500 rv rooftop A/C runs fine when plugged in to normal power but when hooked up to a 4000 w gen.runs for a while then kicks breaker have tried on 2 different generators any ideas
Are both the test breakers the same size (15A or 20A, etc)? Perhaps the breaker in the RV has a lower amp rating then the other one you are testing it on? If that's the case your test doesn't really tell you anything, they both need to be the same size to know where the problem may be.
Aug 08, 2014 | Brisk Air Dometic A/C Roof Top Air...
413h coleman
Do you mean unleaded? Officially no, unless it's marked "unleaded" or "dual fuel" (in Coleman speak, dual fuel means unleaded gasoline OR white gas) which means all the seals are rated for the additives in road fuel.
Unofficially yes, but gasoline is not a good idea because it tends to clog the generator with soot, it goes stale very quickly and it smells bad.
I would stick to Coleman fuel, Primus Powerfuel or Aspen 4. You probably don't get through so much of the stuff that cost is a big issue.
Aug 03, 2013 | Coleman 2 Burner Dual Fuel 424-700G Grill
Are there different head sizes for a tennis racket?
there are 3 different head sizes of rackets. here is an explanation of the different sizes from http://www.dummies.com/how-to/content/choosing-a-tennis-racquet.html
Over-sized:
Beginners really like the over-sized and even jumbo frames, which offer between 100 and a whopping 140 square inches of strung surface. Such frames give you a larger sweet spot simply because the hitting surface is bigger, and they allow you to hit the ball farther from the heart of the sweet spot and still make a good shot.
Mid-sized: These racquet heads range from 85 to 100 square inches. Most pro players use frames on the low side of mid-sized - between 85 and 95 square inches. Most recreational players gravitate to the high side of mid-sized - between 95 and 100 square inches. Mid-size racquets offer a great compromise between a larger strung surface and sweet spot and a maneuverable frame that lets you generate good racquet speed when you swing.
Standard-sized heads: Ranging from 80 to 85 square inches, standard-size heads are now obsolete. They give you a smaller strung surface and sweet spot, making it more difficult to produce crisp, clean shots.
Feb 20, 2013 | Sport & Outdoor - Others
I just puechased a ryobi rg 6900 generator and it does not hahe a battery or operators manual. I need to know how to operate it and what size battery to buy
The RG-6900 Ryobi generator does not have (or need) a battery. It is a manual type with cord start. Voltages and specifications may differ slightly depending on which country the unit is intended for (110V vs 220V). The same applies to warranty and servicing agents.
Send your email address to eggie-at-scheffler-dot-co-dot-za and I will mail you the manual in pdf format (820kb). Substitute "at" and "dot" with the usual symbols to mail me.
i just puechased a ryobi rg 6900 generator and it does not hahe a battery or operators manual. I need to know how to operate it and what size battery to buy
Feb 27, 2011 | Garden
We have a power back generator 5050 watt we are trying to install the cord to plug into our house, what size cord do we need
If you are wanting to connect using the 120/240 outlet, I would use a #12 gauge 4 wire cable. If over 25 feet, then I would use a #10 gauge. The wire size will make a difference, so that is why I am offering the two sizes. Please make sure that you have a transfer switch if you are connecting to the panel. This will prevent someone from getting seriously hurt or killed.
thanks Joe
Jan 10, 2011 | Coleman Powermate Powermate 5000W...
Air cap on ignition module Echo PB-413H blower
The air-gap between the ignition coil module and the magnets of the flywheel is a close tolerance. It is adjusted to about .010"-.012". This is approximately the same as the thickness of a standard size business card. I double the cover and let the magnets on the flywheel (lined up with the coil legs) pull it in tight 9compressing the paper card) and then tighten the adjustment screws. The screws have been known to vibrate loose and the gap would be lost. You can use threadlocker on the screws (optional) or just tighten them down well. Too large an air-gap is bad, but the closer the air-gap, the stronger the spark.
Dec 26, 2010 | Echo Garden
Coleman 425F stove generator
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 14, 2009 | Coleman Gas Grill Stove
What generation nano do I have?
I don't know it by model number but the generation are easy to define.
A first generation nano is either black or white.  It is made out of the same material as a standard Ipod at the time.  Comes in 1 gig and 2 gig only
A second generation nano is multi colored and made from a metal case.  Similar in design to a mini.  The edges are round as well. comes in 2 gig and 4 gig.
A third generation nano is a different size than 1 and 2.  it has a bigger screen on it.  Can play videos as well.  Comes in 2 gig, 4 gig, and 8 gig as well.
Sep 09, 2008 | Apple iPod nano
Having a problem with burners not generating .
so you have a yellow flame, not blue?
my mate had same problem. He now uses unleaded, adding 10 drops Redex to a gallon.
He was also told not to overfill the tank - just 3/4 full.
Works much better but he says not perfect.
Ian
Aug 24, 2008 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman Gas Grill Stove Logo
134 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
