I love my old HP calculators, especially my 10C, 11C & 15C. However whenever I try to get the square root of a number on my 15C I get a Error $ message. How can I remedy this situation?
  • 1 more comment
  • brad504 Sep 27, 2009
    It was Error $ not error $. I also thought about resetting the 15C and agree with you that it could also take care of the constant user mode. By the term reset we are talking about pulling a battery for a short period and then replacing it right?
    Humm, I am trying to write error 4. Ok, well I did reboot the power by pulling a battery, but when I put it back in I am at the same situation being that the 'square root' and 1/x functions bring the error 4 message and it is still in user mode.........help?
  • brad504 Sep 28, 2009
    I appreciate all the input. I submit that the reason I am getting the ERROR 4 is that the calculator is in the USER mode. If I could get it out of USER mode, I think I would funciton properly?
  • 360 Answers
Don't worry I have more coming,
Error 4- You have 322 occupied program bytes and you try to load more program lines
Posted on Sep 26, 2009
  • 5 more comments
  • Richard Klein
    Richard Klein Sep 26, 2009
    Here's the site for a copy of the owners manual
    http://hp15c.org/hp15c.pdf
    I'll still be looking for Error $. Haven't found it yet. All errors are numbers except the power off error you stated. I look in more detail for you.
  • Richard Klein
    I'm going back through the manual, I'm on pg 50 and haven't come across Error $. I think it is a system error that you are not suppose to get. However, I'm going to figure it out. If you have any more questions just respond on your posting here, and it will send me an email immediately.
  • Richard Klein
    I think your right that you may have to reset. 1/x is only ref to matrix's so, I hope your not doing a illegal condition. Then again, I can't see how it could only be in ref to matrix's. I don't want to tell you to delete your memory, you probably done a lot of work to input the memory into the calculator system. I read the manual twice, pg 64 is missing. I'm really surprised it didn't give you an error 9, for fault in circuitry if system memory was at fault. But, it didn't so, I believe you should be ok to reset. That may allow you to get out of user mode too. Hope this helps. Like I said, "if you have any more question, just post a comment at this posting, and I'll respond immediately".
  • Richard Klein
    Richard Klein Sep 27, 2009
    Yes, reset is pulling the batteries for a period of time. I just wonder if the period of time is long enough for the capacitor to be completely discharged, and erasing all of the user memory. Error 4 is saying that apparently the user memory is still there, and when you use 1/x function it must be, or something is using some of the user and system memory to preform the function, and can't because, none is available. Error $ is a locked up system memory error telling you the calculator needs service repair by Hp. I was hoping to get rid of the system error by resetting the user memory allowing the calculator to resume the normal system functions. I thought that because, you didn't get a Error 9 which is a system board circuitry error but, apparently the Error $ takes more precedence.
    If the calculator is still in user memory then the reset did not work. Now, I was told to leave the batteries out for a day but, found that 4 hours worked but, that is on different devices too. Now, if you leave the batteries out for a day, and when you put them back in, and the calculator doesn't reset, I believe it is broken and needs servicing by HP. I am real sorry, I thought we would have a better out come, and we still might, if leaving the batteries out longer works to get the calculator to reset. That is the best I can do for you.
  • Richard Klein
    If you go to the middle of this page at this site you will see in the hp 15c section a statement (available here), and click on to it, it will download a hp 15c simulator that operates just like your calculator on your computer. It is fast and easy to use. You do have to have WinZip on your computer to unzip the download. But once you have the folder unzip, just double click, hp 15c.exe and it will install the simulator. It stores it in the windows folder so, do a windows search for hp15c. The search will display all the hp 15c files and double click hp15c,exe again, and the simulated hp15c will appear on you computer.
    http://www.hpmuseum.org/simulate/simulat...
    I know this may not be what you want or even help you. I'm just trying to help.
    And I am also taking for granted that you use microsoft product installed on your computer too. But, it should work for apple also.
  • Richard Klein
    Richard Klein Sep 28, 2009
    Do a self test, as shown on pg 262 of the user manual. If the calculator passes then there's a good possibility that the (user/program) mode key is stuck, and if you can't free it, you need to get it serviced by hp. If the calculator fails the test then you need to get it serviced by hp.
  • Richard Klein
    You have to be in program mode to delete programs but, being stuck in the user mode, if you could find a way to delete enough of anything such as non system variable it may free up enough memory to allow the system to run right. This is taking in to consideration that the user mode key isn't stuck, and the calculator doesn't need repair. I know your a real smart person, you would have to be to program this calculator. Resetting the programming only take you back to line 0000, and resetting the calculator by extended period of time by taking out the batteries had to of erased all the program memory. That is why I believe the calculator is in need of repair. This calculator if not in heavy use can function for a month on low battery power. You may have to go a full day with the batteries out, in order to get it to do a system reset.
Square roots doesn't work
Two ways the calculator may work:
Enter a positive number then press the square root key, or
Press the square root key then type in a positive number and press =.
Feb 09, 2016 | Texas Instruments TI-15 Calculator
What key strokes are used on Hp12 C for square root calculation?
Put in the number you want the square root of, then press g [square-root].
g is the blue shift key (third key from the left on the fourth (bottom) row of the keyboard). square-root is on the 1/x key (second key from the left on the second row of the keyboard).
May 14, 2014 | HP 12c Calculator
Press numbers display syntax error how solve a problem?
The order in which you are entering numbers and operations is not correct. For example, if you enter 5++2 most calculators will flag this as a syntax error.
On some calculators you calculate square roots as follows: 25 [SQRT]= gives 5. That is the correct syntax for this type of calculators.
For the newer ones you press the SQRT key and see displayed the square root symbol followed by a left parenthesis. You enter the number, close the right parenthesis, then =. If you do not respect the order you get a syntax error.
I cannot say more because I have no idea what you were trying to do, and more importantly, I do not know the make and model of the calculator.
Oct 28, 2013 | Office Equipment & Supplies
HP 15C commas and decimals interchanged
Turn the calculator off, press and hold the decimal point key, press ON, then release both keys.
Apr 20, 2013 | HP 15C Scientific Calculator
SYNTAX ERROR
I am willing to bet that if the calculator could talk she would tell you to stop feeding it commands that make no sense. Joking aside, each command has a certain syntax, similar to sentences you make in English: a prescribed order of the components of the sentence.
For some calculators (the older generations) you press a number then the square root key to get the square root. For the newer ones, you press the square root key. The calculator keeps waiting until you enter the radicand, then it calculates the root.
So before using the command you must know in what order to press the key sequence. If you get an error with a certain key order, do the opposite.
Now, why is the calculator giving you a syntax error always?. There could be may reasons.Try a simple addition or a multiplication. If you get a syntax error, it may be due the computational mode. You may be in statistics mode , or some other modes, I cannot begin to guess, because you say nothing about what you were doing when you get the errors.
Try to reset the calculator to get to default computational mode.
May 22, 2012 | Casio Office Equipment & Supplies
Can I use the HP 12c to figure out square roots of numbers
Absolutely. The square-root function is the blue g-shifted function of the y^x key, 2nd row, leftmost column.
As an example, to calculate the square root of 5, press 5 g [square-root].
Jun 06, 2011 | HP 12c Calculator
I cant figure out how to get the square root of a negative number
The square root of a negative number is an imaginary number, and the TI-30XA does not deal with imaginary numbers.
However, the square root of -x is equal to i times the square root of x. So, to calculate the square root of -4, for example, press 4 square_root = and read 2. Thus the square root of -4 is 2i.
Oct 07, 2010 | Texas Instruments TI-30XA Calculator
Square Root
Don't forget to close the parentheses.
To compute the square root of 2, press SQRT 2 ) ENTER
Mar 09, 2010 | Texas Instruments TI-15 Explorer...
Abs( and square roots
The missing error means that you did not close the parenthesis. When you use a square root or absolute value it always gives you the left parenthesis, (, but you need to close it with a right parenthesis, )
Sep 25, 2008 | Texas Instruments TI-89 Calculator
228 people viewed this question
jasbo
jasbo
