Question about Sony DCR-HC52E Mini DV Camcorder
Your how can i load my footage to pc from sony DCR-HC52E via firewire
  • Sony Master
  • 497 Answers
Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!
Posted on Sep 27, 2009
How woul i connect my handycam to pc
First install the software that came with the camera. I can't find a manual, but I think the camera has a firewire connection. Older MAC's did have Firewire, but for a PC this is different. If you are sure it is not USB, but firewire, and your PC does not have, you could try to buy a firewire interface card that goes in the PC.
Sometimes it is cheaper to by a new camera. But if you still have lots of recordings, you need a correct interface.
Nov 05, 2013 | Sony DCR-HC52E Mini DV Camcorder
I dnt hav usb cable for my handy cam DCR-HC52E ...
Product Summary
    4-pin to 4-pin IEEE 1394 iLink FireWire Cable dv out to laptop Connect and transfer home movie from your digital camcorder to Notebook computer.
    You will need a Firewire port on your computer, also known as a DV port or IEEE 1394, to use this cable. This is NOT a USB cable.
    This DV cable will connect your laptop (notebook)
    NOTE: for some models, becuase of no DV jack on the body, this cable connects to docking station/cradle instead of connecting directly to your camcorder.
Mar 20, 2011 | Sony DCR-HC52E Mini DV Camcorder
How do you capture footage on a miniDV cassette from a Sony DCR VX-2100 Digital Handycam on to a PC?
If you have Windows Movie Maker installed, this would be very easy. Just connect the Camcorder via the FireWire supplied. Go to Windows Movie Maker and select CAPTURE from device
Feb 19, 2011 | Sony Handycam DCR-VX2100 Mini DV Digital...
Is there any firewire port IEEE 1394 (FireWire/i.LINK)in sony hc dcr 52e
Yes, DCR-HC52E has IEEE 1394 port, it would be labled as iLink or DV
Check left to power jack.
Thanks.
Nov 25, 2009 | Sony DCR-HC52 Mini DV Camcorder
Don't have software
http://www.sony.com.au/product/dcr-hc52e/sku/dcr-hc52e+++au2
I also have send my request to sony to update DCR-HC52E software link and i get positive results from their end
Nov 24, 2009 | Sony DCR-HC52E Mini DV Camcorder
Sony DCR-HC52E connected with Firewire not detected in moviemaker
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Sep 15, 2009 | Sony DCR-HC52E Mini DV Camcorder
Can't Import Footage Via Firewire with Sony DCR-TRV900E and Vista
Hi nash
I ma having the same problem... Did you get a solution in the end?
Mar 16, 2009 | Sony Handycam DCR-TRV900E Mini DV Digital...
I don t have cd of the software
yup..i donwld the s/w..and installed it..but how to start the application?
can u help me..
Dec 24, 2008 | Sony DCR-HC52E Mini DV Camcorder
Download to my computer
Hi Heart of Chr....
Here is the USB driver for your Sony Handycam DCR-HC52e:
http://www.camerahacker.com/Forums/Video%20Camera/Sony/Sony_DCR-HC21_xp_driver_needed.files.hidden/USBDRVEN.EXE
The Firewire driver is already bundled with Windows XP.
Software for viewing, editing and transferring:
DCRHC52 is compatible with Windows Movie Maker & Apple iMovie,meaning you can usually begin editing your footage straight away usingthe software already installed on your PC.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Sony DCR-HC52E Mini DV Camcorder Logo
339 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
