Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
Will not go on ...all cycle lights light up put start will not activate. have unplugged to reset...to no avail...motor part was replaced 11/11/08 . machine is only 2 years old and only used in summer months about 2 times a week. what a disappointemnt!!
  • eromagn634 Sep 26, 2009
    touch panel lights up but power will not go on. have reset, have checked hose an drains
    President:
  • 1,015 Answers
It is possible that the control panel might be bad. Remove the inner panel on the dishwasher. Then inspect the ribbon connector and make sure it is fully seated into the the panel and control board. Carefully inspect the ribbon connector for any shorts that may have happened on it. It is possible that the ribbon connector has shorted out...that is what happened to mine. I had to get a new control panel due to the ribbon connector is part of the control board. If you look at the ribbon connector very closely you might see a small spot that has shorted. Those individual lines are wires and should look the same all across the ribbon connector. Let me know what you find.
Posted on Sep 26, 2009
  • muebe Sep 26, 2009
    The touch panel can still light up even though it is not working properly. If the panel is ok then you will need to verify the control board is working. When you start the cycle the control board should be sending a signal for the water inlet solenoid valve to open and begin taking water in for the wash cycle. You will need to use a fluke meter to test the wires going to the valve and make sure it is getting voltage. Usually 24 volts.
    Also verify the door latch switch is not defective and door is closing tightly. The switch is usally located inside the door panel where the latch enters the door.
  • Frigidaire Master
  • 19,396 Answers
If you already disconnected power, ensure that there is no water inside the machine. Then check drain well and filters, check inlet hose, and try restarting the machine.
If there are still problems, then the machine is faulty. If the dishwasher is two years old, it is either in warranty , or the warranty has recently expired. Frigidaire dishwashers have 2 years standard limited warranty on parts and labor.
If the machine is less than two years, have it repaired under warranty.
If it is over two years, call Frigidaire - Customer Support at 1-866-386-5286 (toll free) , and try to purchase a warranty extension to five years, you may still be in time, and this will cover you toward any future problem.
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
F1 error at start and either at 21 minutes or 19 minute mark during cycle. I have to push restart and start several times to get machine to work.
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#%^
Aug 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am recieving a F1 fault code shortly after start up and periodicall through the cycle. HELP!!!!!!!!!!!!!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%@#$^
Aug 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am getting the F1 error message everytime I use my washer with all cycles. I keep hitting pause then restart until it finally completes but sometimes it may restart 5 or more times to complete rinse/spin...
Jun 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am getting an F1 error on the washer
Jul 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Every time I start the machine the f1 error comes up within a few seconds. have to press pause & start about 3 times & it will finally start to work. have to do this several times during the entire...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^@#$%
Jun 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 during the fill cycle
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^%$
Sep 26, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
WTW 66005W1 cabrio, F1 error code.?????Machine error code at start and during rinse cycle. What is causing this? Any quick fix?
Jul 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Lights on Washer Machine flash but Washer doesn't work
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Mar 31, 2009 | Kenmore Washing Machines
Problems Keeping the cycle going
On the back of the selector switch there is a timer motor or clock motor assembly. The gears wear out or the motor has lost its ability to go through the cycles. Replace it and you should be fine.
Jan 16, 2009 | Dishwashers
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
332 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
