Question about Pride New Mobility Legend 4 Wheel Scooter
Electrical fault My lights,horn and indicators wont work but my hazzard lights do work? All fuses and bulbs are ok.
  • Pride Master
  • 1,271 Answers
Sounds like a problem with the circuit board under the speed pot,
It could be a loose connection and remember there can be a fuse under there.
Regards
Gewiz
Posted on Oct 02, 2009
Testimonial: "THANKS WILL CHECK IT OUT "
Drivers side brake light and horn won't work,,is it the multi function switch? 1999 chev blazer 4x4 . if so how much does a new one cost?
No there not connected, replace the brake light
1999 Chevrolet Blazer Auto Light Bulb Size Guide
Low Beam Headlight Bulb Size: 9006
High Beam Headlamp Light Bulb Size: 9005
Parking Light Bulb Size: 3157
Front Turn Signal Light Bulb Size: 3157
Rear Turn Signal Light Bulb Size: 3057
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: 880 or 881
License Plate Light Bulb Size: 194
Back Up Light Bulb Size: 3156
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 161
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 168 or 211-2
Step/Courtesy Light Bulb Size: 168 or 211-2
Trunk/Cargo Area Light Bulb Size: 211-2
Under Hood Light Bulb Size: 93
Instrument-General Light Bulb Size: 161 or 37 or PC194 or PC74
Check Engine Indicator Light Bulb Size: PC74
Hi-Beam Indicator Light Bulb Size: PC74
Seat Belt Indicator Light Bulb Size: PC194
Brake Warning Light Bulb Size: PC74
Automatic Transmission Indicator Light Bulb Size: 194
Directional Signal Indicator Light Bulb Size: PC74
As for the horn, inspect the fuse and relay and most common it would be a bad ground wire or worst a bad horn due to corrosion. Horn will be located in the drivers side fender.
Thank you for using fixya.
May 13, 2010 | 1999 Chevrolet Blazer
I HAVE A 2002 JEEP WRANGLER SPORT. THE HAZZARD LIGHTS DONT WORK
I think there are 2 fuses for those switches. Fuse #11 & #39
Hope that works for you
Feb 22, 2010 | 2002 Jeep Wrangler
Tail lights don't work, but brake, flash and hazzard work.
generally when the fuse is ok and the bulb is ok the problem is corrosion of the ground wire and connection to the frame, or corrosion in the bulb sockets. for starters go to any auto parts store and get an aerosol can of contact cleaner especially for auto bulbs and connections.
Aug 28, 2009 | 1984 Pontiac Fiero
My brake lights wont work,i checked all the fuses,bought new bulbs,and bought a brake switch,and still nothing.my regular lights come on,just my brake lights dont work.dont no if this is part of the...
Just had a similar problem. Brake (stop) lights and horn didn't work. Couldn't find mention of stop lights in fuse chart. Found horn fuse to be slot 21 in the engine fuse block (not the fuse block in car interior). Replaced 15A fuse and all now ok.
Aug 21, 2009 | 2005 Mazda 3
My left indicator isnt working,the rest are though
need more info ??does it work with hazzards on ??all four lights?'
Jun 14, 2009 | 1999 Volkswagen Passat
Cant get indicators working
there is a gray block fuse under the hood that could control the light
take it out and take it to auto zone and have checked this good be the
easiest fix but it will cost about $25.00 for that fuse!
Apr 09, 2009 | Hyundai Motor 1999 Elantra
Lost lights
hi as you have checked all fuses for these light ok? and other lights are all working may i suggest you check the relay for side/tail lights which also includes licence plate light first it sound like the relay has failed if you look under fuse/relay cover you may find map indicating location? i would try this first b4 switch hope this helps?
Oct 22, 2008 | 2003 Ford Focus
Pride New Mobility Legend 4 Wheel Scooter Logo
224 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
