Washer will not spin
Hello ,fisher and paykel ecosmart washer will not start spin cycle, it will try to start but never dose and the lid wont lock like it should in spin cycle
  • Anonymous Mar 15, 2014
    spin light on washer wont fill and lid lock light on but lids not locked
  • Anonymous Mar 24, 2014
    tried every cycle. Lid does lock then starts flashing
    Sergeant:
  • 288 Answers
I'm having a little trouble understanding the question because of the spelling, but this sounds like a typical lid switch not making contact either by the depressor on the lit itself or the switch is broken. try depressing the switch with a screwdriver and see what happens. The lid switch will be in a little slot in the top inside where the lid closes.
Posted on Dec 18, 2007
Aquasmart lid
Is the lid lock tang on lid broken.
2.9 Lid Lock
The Phase 7 Washer uses the same lid lock that is used on
the Phase 6 series 11 & 12 machines. The difference being is that the lid is now locked for the entire cycle. When the lid is locked the Lid Locked LED will illuminate. Once the spin
has completed, the lock will release and the lid can be
opened. To open the lid during the cycle the
START/PAUSE button must be pressed, the machine will
come to a halt, and the lid locked LED will extinguish.
If the lid is left open, the machine will be unable to lock the lid
and the cycle will be halted. The machine will play a tune
and the lid lock will flash until the lid is closed and START/PAUSE is pressed.
• If the lid-lock fails in the closed position, the locked lid can be forced upwards and out of the
lock. Note: This is the only time in which we would recommend doing this.
• If the harness is damaged, the complete lid lock assembly will need to be replaced.
If the power supply is cut during the spin cycle, the machine will keep the lid locked until the rotor has ceased to turn (3 to 10 secs). Only then will it release the lock. The motor is acting like a generator and allows the lock to stay energized under the bowls inertia.
Mar 16, 2013 | Fisher Paykel EcoSmart GWL15
Fisher and paykel model no GW611 washes but won't spin nor lid locks
Sounds like the lid lock has gone bad. Check the wire connections to it and if you should need to order the lock, here is their website.
Nov 05, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
Jul 28, 2011 | Fisher and Paykel WA37T26G Top Load Washer
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
Fisher Paykel Ecosmart (about 6-7 years old. Spin
better get e a new one, it is most likely the bearing , can u see small amounts of water under the machine, if u want to take the top off all there r is 2 screws under 2 D shaped covers under the lid towards the front of the machine ,,,,wont help , but it also cud be a wire in the drain pump
Jan 28, 2010 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Sep 30, 2009 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel Ecosmart will Wash but not Rinse/Spin
You have too many clothes in the washer. Take some out and try again
Sep 09, 2009 | Fisher Paykel EcoSmart GWL15
Fisher & paykel machine locked but lid is up
It sounds like the lid lock is either stuck or broken,You will need to lift the top hob by removing the two plastic lugs where the lid rests & removeing the screws it will then lift up and you will be able to remove the lock to inspect it,Also you can remove the lid in the up position by pulling vertically to make it a bit easier,Hope this helps Cheers.
May 21, 2009 | Fisher and Paykel Fisher & Paykel Washer
My f&p is not draining or spinning
You have a broken lid switch that needs to be replaced. The washer thinks the lid is open. A model # would be helpful. thanks dave www.washermd.com
Dec 16, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
452 people viewed this question
Top Washing Machines Experts
