Question about Husqvarna Viking 1
Have a husquvarna viking 200 machine and the bobbin has stuck on the mechanism while I tried to remove it after the bobbin was filled. Have pulled and pulled and it simplyu will not come off. Thanks for your help.
    Novelist:
  • Husqvarna Expert
  • 371 Answers
I'm assuming you are talking about the rewinding mechanism on top. There are grooves in the bobbin which fit on to the rewinding spindle that holds the two together while the bobbin fills. It may be they have gotten out of synch or the bobbin is a non-standard Husqvarna Viking bobbin for that machine. These usually use green bobbins but they have come out with new colors but all have the Husqvarna logo on the bobbin -- an H. I would try to wiggle it slightly to try to remove it. If still will not come off, try popping it off with a flat head screw driver but be sure to put a folded towel under the screwdriver so that you don't damage the molding of the machine. If you still are unable to get it off, recommend taking it to an authorized Husqvarna Viking dealer. A list of dealers near you is available at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Posted on Sep 26, 2009
Unable to remove bobbin from bobbin threader till almost all thread removed. Viking 1+
You could stop the bobbin filling process just before the bobbin is "full."
Most machines have a finger that rides against the area being filled; maybe this is bent?
Feb 22, 2015 | Husqvarna Sewing Machines
I just inherited another Huqvarna (this is a model 630). It was working great until I wound a bobbin on it. After I removed the filled bobbin the machine won't move the needle up and down (but the bobbin...
I do not know the Husqvarna Viking 630. However, I have used the Viking 6690 and it has a similar on-the-side bobbin winding routine. I suspect that you failed to move the bobbin winding mechanism back into the sewing position. Look closely at the area around the bobbin winding spindle. It looks like there is a lever below the spindle. Does this need to be moved or rotated? Double check the steps in the manual and check that you did the opposite steps of preparing to wind the bobbin.
On the 6690, you pull out a knob after removing the bobbin. (You push this piece in and put the bobbin onto the now exposed spindle for winding.)
I hope this helps.
Dec 21, 2014 | Sewing Machines
Knife cutting knives
Remove the stichplate and snap out the plastic cover over the thread cutter (left most end of machine). This exposes the thread cutter mechanism. You should then be able to position the knife arm back into the mechanism (two pins on the cutter mechanism that insert in a hole in each actuating arm).
Apr 11, 2014 | Husqvarna Viking 1
Do not know what size prewound bobbin i need to buy for a white 3300 embroidery machine
try this link, sewing parts on line says this is the bobbin for your machine, compatible with some Whites and Husquvarna Viking machines.
http://www.sewingpartsonline.com/bobbins-viking-white-10-pack-4120612-45.aspx
Genuine Part #412 06 12-45 or alternate code is 11770P
Jun 06, 2011 | White Sewing W3300 Computerized Sewing...
I took my Viking Husquvarna Sewing Machine (Model 5605 Rose) apart and cannot figure out how to put the clip back in on the inside. I need a photo of the internal schematics for the machine.
I just got a Husquvarna Viking, Rose machine, i do not know how old it is, but i can't find the model number, and i wuld also like to see how the bobbin case should look.
thank you, Graci
Mar 27, 2010 | Husqvarna Rose
How Need to know how to thread the machine and how
They have many different models so threading and winding the bobbin can vary due to your model. I would recommend calling them at: 1-800-474-6437 and see if they can get you a photo copy of your original owners manual.
Oct 15, 2009 | Husqvarna Viking 1
Bobbin stuck on winder
Sometimes when a bobbin is wound very fast the plastic gets hot and misshapen, and you can't remove it. Nothing for it but to break the bobbin - it's useless now anyway even if you could get it off in one piece. Pull off as much thread as you can and use pliers or something similar to break enough of the bobbin so it will come off. You need to take care not to let little broken pieces fall into the machine mechanism and take care not to yank too hard on the bobbin winder spindle. If all this scares you too much, take the machine to your dealer for help. And remember to slow the machine down a click or two when you wind bobbins! (It may be of some comfort to you to know that every user of plastic bobbins has done this at some time!)
Jul 21, 2009 | Husqvarna Viking 1
Viking sewing machine 545 bobbin stuck on rewind
It should just pull off of the winder shaft. There is a small spring that sticks out from the shaft to hold the bobbin in place (at least on my wife's Viking which is a different model number than yours). Is there a release button somewhere near?
Jul 17, 2009 | Singer CE-100 Futura Computerized Sewing...
Bobbin does not wind all the way up
I have had this problem, easily fixed by twisting the rubber knob that is in contact with the spool to the left.
Feb 08, 2009 | Husqvarna Lily 540 and 550
I filled the Bobbin, now how do I get it to go back to sewing
Something didn't click back in place when you removed the bobbin from the winding mechanism. Try winding another bobbin. Make sure it stops, then remove it. If the problem continues, take it to an authorized Husqvarna Viking dealer. They should still be able to take a look at it. Check Husqvarna Viking website for dealer closest too you.
Dec 16, 2008 | Husqvarna Viking 1
Sewing Machines Logo
150 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
