Question about Toshiba Satellite Pro L300 Notebook
When I turn on my computer all I get is a lit blank screen.
  • teresamccalv Sep 26, 2009
    i pulled the ram out and put in back in and still didnt work
  • 4,281 Answers
First let me know that can you get bios screen on display.
For that when you power up the computer press F1 or F2 or "del" key then you can enter in bios then check your harddisk is detect or not.
If not then disable SATA option go to boot option and set first boot devcie as your harddrive. then save settings and exit.
If still not get dispaly then you have to refix
RAM memory.
It is in back side of laptop.
You find 1 plate open it then you see RAM .
Pull it then reseated it.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 26, 2009
  • ok now you have to reset all your bios settings.
    For that open back cover of laptop then find motherbord .
    Pull cmos cell from motherbord 10 minutes .It is round cell look like battery cell then it reset to defaults.
    Thanks.
Unit comes on,runs for ten seconds,(w sign on page on screen)then turns off.
"Hello, Sounds like you have a bad monitor, or video cable, replace."
Nov 08, 2015 | Computers & Internet
Power turns but screen stays black no
Sounds like you need a new LCD Screen(is the screen a little lit up or completely blank) If completely blank than most likely the LCD needs to be replaced if it appears to be slightly lit up than most likely it is a software related issue.
Mar 31, 2014 | HTC Cell Phones
My HP pavillion g series,it turns on but the screen stays blank and dark
My computer doesn't flicker any colour before it goes blank etc. When i turn it on, the screen is blank/black and It says its on.. by the light being lit up, but nothing happens. :/ I don't understand, whats the problem?
Apr 26, 2012 | HP Computers & Internet
No display
The following applies to Acer Laptops...
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
May 09, 2011 | Acer Aspire One PC Notebook
The computer will start up but the screen will be blank
Try plugging in a regular computer monitor, if that works then you will need to open it up and check the screen's connection. if you get now lights from the regular monitor then you will need to check you ram/memory to see if it is connected properly.
Feb 27, 2010 | HP Pavilion dv9000z Notebook
Screen is just lit up blank cant turn off or get
were you trying to unlock or jailbreak it ? be that as it may remove the battery for about 10 minutes and then try and turn on the phone again. should work unless the error occured while you were doing either of those two things
Oct 21, 2009 | Apple iPod touch
Monitor is blank when we turn the computer on.
Maybe not. Find the FN key. It is usually BLUE in color
Then look on TOP row of Computer keyb (or all over) and find CRT/LCD.
Press the FN and that key and your screen should come back. You accidentally sw. it to CRT (outside, external monitor)
Jan 14, 2009 | IBM ThinkPad T23 2647 Notebook
SCREEN BLANKS WITH POWER LIT GREEN
Look for bulged or leaking capacitors on the power supply board. If you can solder, you should be able to replace them with the same type and rating and that may just solve the problem. I've had luck with a couple of dozen monitors so far.
Mar 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Blank screen appears when turning on
tried reset ?? take backup 1st
Dec 25, 2007 | i-mate JAM Pocket PC
Toshiba Satellite Pro L300 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
