Question about Maytag PYE2300AY Electric Dryer
Dryer very noisey when drum turning - Maytag PYE2300AY Electric Dryer
  • Maytag Master
  • 7,482 Answers
This problem is normally cause by the drum rollers having flat spots on them and or needing lubricant or replacement.
Posted on Sep 26, 2009
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
fgs
Posted on Sep 29, 2010
When drying it its sounds like shoes bouncing around
Have it looked at: many use a belt that turns the drum the clothing is in and it may have rubber like wheels that have worn or are flattened on one side--worn wheels if it has it will cause this issue.
Dec 04, 2012 | Samsung DV337 Electric Dryer
Very noisey and rattles
check the spindle on the rear of drum. its positioned in the centre of drum
Jan 31, 2012 | Zanussi TD4112W Electric Dryer
The drum is very noisey and is leaking grease on items.
hello sorry to say that it sound like the bearing have gone you can do quick test open the door grab hold of the drum pull up and down if this moves freely then the bearing have gone
regards
shaun
May 28, 2010 | Washing Machines
Noisey dryer
if the drum is noisey the belt tensioner bearing went bad
Feb 14, 2010 | Dryers
Dryer making noise when turned on
you have to specify what make your dryer is to be able to answer question
Feb 06, 2010 | Dryers
Dryer squeqks while rotating
It could be a noisey idler pulley that belt rides on, or a noisey drum bearing or drum glides, or even possibly a motor bearing going bad. Would need to be checked by repairman to determine exact cause.
Feb 04, 2010 | GE DBXR463GB Gas Dryer
My white k knight condenser tumble drier is very noisey when i turn it on the model number is 7670
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 14, 2009 | Dryers
Whirlpool dryer making noise and shaking! The bin
The dryer has "rollers" underneath the dryer drum that support and allow the drum to roll smoothly when drying.
I believe one or both of your rollers are worn out. In either case, make sure you replace them all or you will be doing this again in the near future when the other one decides to fail.
Below is a diagram of the rollers ( #44 ) that need to be checked and replaced.
Let me know.'
Regards,
May 15, 2009 | Whirlpool LER5636P Electric Dryer
Question on posting...
If your dryer is kenmore its probably not the blower this dryer has 2 drum rollers at the back that the drum rides on they could be noisey also theres a idler pulley that the belt uses as a tensioner that could be noisey they sell a kit with all those parts thanks THE APPLIANCE DOC
Sep 02, 2008 | Kenmore 63012 Electric Dryer
How to check belts ?noisey
ok sound like the drum rollers need replaceing
take the screws off back that hold down top lift off top
unscrew front of dryer , it will come off
pull drum out after takeing off drum belt
replace rollers and belt
be sure to notice how belt goes on before taking it off
take model number and make of dryer to appliance parts store
get roller kit and belt
Jan 20, 2008 | Dryers
Maytag PYE2300AY Electric Dryer Logo
77 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
