Question about Electrolux Dryers
No error code but dryer drum is not turning - Electrolux Dryers
  • Electrolux Master
  • 7,482 Answers
Check to see if the drum belt has broken or slipped off of the motor pulley or idle arm pulley...sometimes that is the problem.
You can also turn the drum by hand a 1/4-1/2 turn with the dryer turned off , then try again to start the dryer. Sometimes motors will get a dead zone in them and this will help them to start.
Posted on Sep 26, 2009
Dryer drum and motor won't turn.
See if the motor turns if you directly hook it up to electricity. If it does then the electronics are at fault. If no turning the motor itself is bogus.
Aug 10, 2016 | Whirlpool Cabrio Platinum High Efficiency...
The dryer starts to heat, but the drum does not turn
When you start the dryer do you hear the motor running if so the belt from the motor to the drum of the dryer is broken has to be replaced.
Jan 29, 2015 | Dryers
Dryer not heating
That error code is a motor fault.
Oct 11, 2014 | Electrolux Dryers
LG washer IF82 code. What does it mean? This is a washer not a dryer.
LE error is hall sensor is bad or bearing not letting motor turn
Aug 05, 2014 | LG WFT1071TP Top Load Washer
Maytag washer Model# Mle19PDDGW showing error code D11 whats wrong
D11 is a motor speed error .
is the inner drum turning under power or not?
Nov 22, 2012 | Maytag Neptune MLE19PN Front Load Stacked...
Error code 52, Dryer won't start
You have a motor error. Remove any load from dryer and check if drum turns freely by hand. Check L1 power supply voltage, motorwindings, and motor thermal protector (if motor thermal protector has tripped,it may take up to 30 minutes to reset). If error persist, replace the motor with this new one.
Oct 15, 2012 | Dryers
Electrolux E52 error code Dryer
Hello drew_wedemey -Typically error code E52 indicates that the unit has a faulty motor. If the drum does not turn freely by hand, then I highly suggest contacting a professional to accurately diagnose the following; motor windings, L1 power supply voltage and the motor thermal protector.
Sep 30, 2012 | Electrolux Dryers
Electrolux EDC5340 dryer: drum is hard to turn, error code E50. I can hear the motor trying to turn, so it is not a fuse or open circuit. How do I open the dryer to check for mechanical obstruction or...
you can take off the front panel, there are screws inside the dryer door,may have two on the bottom corners and then gently pry up on the top corners with a flat tip screwdriver. disconnect the door switch and the panel is off. check to make sure the the belt is centered and you can turn the drum. hope this helped tim
Sep 03, 2010 | Electrolux Dryers
Error Code F2
That means the sensor that tells the computer what temp the drum (and the clothes) are so it can cycle the heater on or off according has failed. Please rate my help as solved if i answered your question! THANX
Oct 02, 2007 | Kenmore 84072 Electric Dryer
Dryers Logo
338 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
